Clusters in Ek civics?
Old Jun 17, 2008 | 08:49 PM
36Chitownrunnin's Avatar
Default Clusters in Ek civics?
What clusters will work in a 96 ek civic? I know 99 si will work any other ones because got a gsr motor I was kinda shotting for a gsr one but not sure if will fit.
Old Jun 17, 2008 | 11:26 PM
geneeunit's Avatar
Default Re: Clusters in Ek civics? (36Chitownrunnin)
-96-00 civic cluster will fit of course. (SI, SIR, CTR, etc.. etc..)
-97-01 CRV cluster will fit.
-94-01 integra clusters can work, you have to re-pin the plugs and it wont fit exactaly right. (i have one from a 96' spec itr in my 96 hatch and it works great.)
if i got anything wrong, correct me please.
EDIT:: you could also use an S2k cluster, but its pretty pricey, and a lot more work. a lot.
Old Jun 17, 2008 | 11:27 PM
BlueIntegraBoy's Avatar
Default Re: Clusters in Ek civics? (geneeunit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geneeunit &raquo;</TD></TR><TR><TD CLASS="quote">-96-00 civic cluster will fit of course. (SI, SIR, CTR, etc.. etc..)
if i got anything wrong, correct me please.</TD></TR></TABLE>
You are correct, sir.
Old Jun 18, 2008 | 03:01 AM
Adankid's Avatar
A quick question about this topic, so if your in a stock 99 civic, and you change out the engine and transmission to a 01 gsr engine and tranny,
and fit a ctr cluster in, will the needles on the cluster be marking correctly??
Old Jun 18, 2008 | 03:25 AM
VSM_EJ8_408's Avatar
EDIT:: you could also use an S2k cluster, but its pretty pricey, and a lot more work. a lot.</TD></TR></TABLE>
the 96-00 clusters are they all plug and play ? i have a 97 civic ex planning on getting a si cluster
Old Jun 18, 2008 | 05:52 AM
ricb20vtec22's Avatar
The easiet thing to do it to get a 99-00 SI cluster or a CTR cluster. a GSR cluster or ITR will need to be re-pined & it won't fit correctly.
Old Jun 18, 2008 | 02:42 PM
geneeunit's Avatar
Default Re: (Adankid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adankid &raquo;</TD></TR><TR><TD CLASS="quote">A quick question about this topic, so if your in a stock 99 civic, and you change out the engine and transmission to a 01 gsr engine and tranny,
and fit a ctr cluster in, will the needles on the cluster be marking correctly??</TD></TR></TABLE>
yes.
and all 96-00 civic clusters are plug and play as far as i know.
also, re-pinning for an integra cluster, is really simple. and its not hard to acheive a nice fitment.. IMO.
jdb83923
12
Aug 20, 2010 02:02 PM
h23vtecpowered
Apr 14, 2008 02:30 PM
badboiz530
Aug 21, 2007 07:59 PM
B Hunter
Sep 15, 2005 08:32 PM
el402
May 21, 2002 06:52 PM
