vtec head
to do it right you need the intake and exhaust from the gsr head along with a oil line kit and gasket, do some searching for the kit there is a ls vtec cr vtec kit you can buy. you also need to wire vtec and a knock sensor along with iab wiring if you are going with a gsr manifold.some people also recommend a vtec oil pump as well as a vtec water pump..i have a b20 vtec with a gsr head its torquey
