doing a vtec swap, some questions id like answered, please help
Old Jun 17, 2008 | 05:32 PM
civicminded93's Avatar
Default doing a vtec swap, some questions id like answered, please help
I got a sohc vtec free ( d16z6) from my uncle who is leaving for iraq, I have read and heard some peoples say I can use the stock wiring harness from the del sol its going in, even though the engine currently in the del sol is non vtec, is this true? if not where can I find a wiring harness for it? The vtec is in a totalled del sol SI and the wiring harness may be able to be saved but im not sure. all of your help will be greatly appreicated, thanks.
Old Jun 17, 2008 | 06:51 PM
CivicSpoon's Avatar
Yes you can use it, you just add 3 wires for vtec (one being a ground wire).
Old Jun 17, 2008 | 07:08 PM
z6hatchboy's Avatar
I've read before that all del sol s's wire pre-wired for vtec (not positive though), just as all 92 civics were pre-wired for vtec (dont argue about this one people, its a fact). If so then its just plug n' play, if not then do as mentioned above and wire it up that way. If you need a wiring harness for the head any z6 harnes will work out of any 92-95 z6 equipped civic.
Old Jun 17, 2008 | 08:32 PM
Default Re: doing a vtec swap, some questions id like answered, please help (civicminded93)
ok thanks for your help so far. ok if i have to hook 3 wires up and one is ground, one has to be power, what is the third one for?
Old Jun 18, 2008 | 09:14 AM
CivicSpoon's Avatar
1 ground, 1 for the VTEC solenoid, and 1 for the VTEC pressure switch. http://www.ff-squad.com/tech/w...5.jpg
The VTEC solenoid wire is on a 1-wire plug & the VTEC pressure switch is on a 2-wire plug (one for the pressure switch and the other is the ground wire); so you can tell the difference.
Old Jun 18, 2008 | 09:35 AM
Default Re: (CivicSpoon)
ive never done an engine swap, let alone a swap with a vtec, I am putting a sohc d16z6 in my del sol ( taking everything from the wrecked del sol si is goin on my del sol) so Im not sure how to do this. that link was showing for b series.
DelSolid21
Sep 29, 2010 11:12 PM
rewerbcrx
Feb 19, 2008 08:42 AM
97grnrs
Dec 18, 2005 02:01 PM
vtecpoweredsol
May 15, 2005 06:15 PM
GSR_deLsOL
May 4, 2004 10:52 PM
