what kind of valvetrain to use w/skunk2 or jun stage 3 cams?
just as the topic says.
im planning on getting JUN3 or skunk2 stage 3 cams.
the valvetrain i have on a b16a head is:
portflow retainers
portflow inners
ITR outers
ITR valves
would this setup be okay to run any of the above mentioned cams?
i heard its okay but want 2nd opinions
the head is not p/p.
replies pls
thanks
portflow retainers
portflow inners
ITR outers
ITR valves
replies pls
thanks
I wouldn't reccommend the Jun valvetrain on a daily driver, they've been known to wear out quickly and sometimes fail, but the cams make excellent power, check out the dyno comparisons on importbuilders.com. If you want to spend the money, the Skunk2 valvetrain will work, or if you want to save a little, the crower valvetrain will work also.
low'n'fro
Apr 5, 2008 10:04 AM
