94 civic b18c crazy probs
Old Jun 17, 2008 | 01:11 PM
crxricer66's Avatar
Default 94 civic b18c crazy probs
the speedo inside the car goes nuts sumtimes. if i start getting into the throttle, the speedo will jump to 100-120. sometimes when i hit a bump it jumps from 50 (my speed) to 65 but right back to 50. does the speed sensor need to be greased possibly?? the tach doesnt work either, its a dx model with ex gauges. the tach should work shouldnt it, just plug n play??
Old Jun 17, 2008 | 01:36 PM
crxricer66's Avatar
Default Re: 94 civic b18c crazy probs (crxricer66)
the gas gauage and the heat gauge works, plus all the lights but the tach doesnt.... any ideas?
Old Jun 18, 2008 | 09:06 AM
crxricer66's Avatar
any ideas at all ppl?
Old Jun 18, 2008 | 09:10 AM
z6hatchboy's Avatar
Yes the tach should work. For your speedo problem you need a new vss (vehicle speed sensor), and for the tach if a diff cluster doesnt fix it, then try a different distributor (theres a sensor in there that gives the tach sensor).
Old Jun 18, 2008 | 01:09 PM
crxricer66's Avatar
Default Re: 94 civic b18c crazy probs (z6hatchboy)
i hooked another ex cluster up and it didnt work. its prolly dizzy cuz it has external coil and there is only two wires coming out. so the other wire is prolly not hooked up? thx man
b20acura
Jan 14, 2012 01:02 AM
courtney42
Apr 3, 2009 04:24 PM
civic08
Feb 28, 2008 09:22 PM
chulopilong
Feb 16, 2005 03:04 PM
matt j
Jun 13, 2003 04:35 PM
