rebuild or swap?
Old Jun 17, 2008 | 10:02 AM
jimmy o.'s Avatar
Default rebuild or swap?
I have a 94 EX the motor and trans are out of the carif i were to rebuild i would need the following parts
-bottom end overhaul (it has a knock)
-complete gasket set
-both axles
-flywheel (its cracked)
-header or stock manifold (also cracked)
its a d16Z6
my question is should i rebuild or swap to a b-series
Old Jun 17, 2008 | 10:03 AM
jimmy o.'s Avatar
my goal is 150hp
nothing extreme
Old Jun 17, 2008 | 10:05 AM
davefromPA's Avatar
Default Re: (jimmy o.)
how much money do you have to play with?
Old Jun 17, 2008 | 10:08 AM
superfast666's Avatar
swap
Old Jun 17, 2008 | 10:22 AM
jimmy o.'s Avatar
As much money as i get for selling my RX-7 turbo (cause i cant afford premium+2 stroke oil)
Old Jun 17, 2008 | 11:40 AM
davefromPA's Avatar
everyone on here will tell you swap. and i mean everyone. i like single slammers though and choose to keep them. if i blow it up, ill buy another for a couple hundred. they have potential to make moderate power. and since you only want 150 i say get another z6 and have it made to your liking. dont skimp out on anything and keep it running. tops your looking at 1000 to have it reliable and well built with your specs. a swap to b-series will run you about 1000 said and done and will not be the way you want it. hope this helps more then the normal response of "swap" with no info on what or how much.
jmurphy
58
Mar 25, 2011 06:22 AM
Ryank327
Northern California (Sales)
10
Jun 16, 2009 03:37 PM
93LsVtecIntegra
May 13, 2008 08:07 PM
JEM MotorSports
Jun 14, 2006 04:29 PM
red91g2
Apr 17, 2006 10:17 PM
