JDM 1.5 SOHC Vtec
Old Jun 16, 2008 | 10:49 PM
93JdmHatchSOHCV's Avatar
Default JDM 1.5 SOHC Vtec
ok i have a jdm 1.5 single cam vtec in my civic hatch cx it has
2 1/4 exhust
high flow cat
header
cold air intake
8 ilb flywheel
stage 2 clutch
light weight crank pulley
with a chipped p28 ecu
ok i have a few?'s
how do i get 2 step..?
what should my launch point be..?
i was thinking about shaving the head down 60,000ths what kinda power would that give me ..?
if i port and polish the head should i upgrade the fuel system..?
What else could i do to give me more power trying to go all motor no turbo...
with the cx motor i had in there i had to launch a 5,000 r's
Old Jun 16, 2008 | 11:25 PM
JDM-JAMES's Avatar
Default Re: JDM 1.5 SOHC Vtec (93JdmHatchSOHCV)
just get a cam and some p29 pistons to raise the compression and why would you want 2 step on a na car you only want launch control you would have to get chrome or neptune or any other type of honda bin editor and reburn a new chip and insert it into your chipped ecu or if you want more power just get a d16 block buy my 1.7 liter stroker crank with ported race oil pump and all motor rods would give you some power in na
Old Jun 16, 2008 | 11:39 PM
Default Re: JDM 1.5 SOHC Vtec (JDM-JAMES)
yeah my vtec kicks in at 3700 and goes to 9300 but yeah i was thinking a about a stroker kit but i can find anything for 1.5 parts no pistons or crank or nothing not even springs or valves
Old Jun 17, 2008 | 01:53 AM
boondocks1805's Avatar
If I recall correctly you should be able to use pistons from the D16. The bored on a D15 is 75mm stroke should be 84.5. I am build a D15B7 so I came across this problem as well, Check out CP pistons hear good things about them for the price.If you have any questions feel free to ask. Hope I was helpful.
Old Jun 17, 2008 | 01:55 AM
Default Re: JDM 1.5 SOHC Vtec (boondocks1805)
well if i can use the d16 pistons is the bore the same what is the diff...?
Old Jun 17, 2008 | 01:57 AM
what is the diff between the 1.6 sohc vtec usdm and the 1.5 sohc vtec they have the same horse power and the jdm one has more torque the 1.5 is .1 less then the 1.6 but is way faster i smoke LS's and Some Gsr's
Old Jun 17, 2008 | 05:22 AM
ChInKsTaH's Avatar
TRIAL USER
it should be like at 6 or 65 rpm
Old Jun 17, 2008 | 05:34 AM
speedooo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93JdmHatchSOHCV &raquo;</TD></TR><TR><TD CLASS="quote">yeah my vtec kicks in at 3700 and goes to 9300 but yeah i was thinking a about a stroker kit but i can find anything for 1.5 parts no pistons or crank or nothing not even springs or valves</TD></TR></TABLE>
i give that motor another 2, maybe 3 weeks.
is this an obd1 or 2 version?
Old Jun 17, 2008 | 06:15 AM
1CaMw0nDeR's Avatar
lol why did u set vtec at 3700 and redline at 9300..??? u kno on a dyno chart ur peak power is gonna start to drop way before that so all you're doing is potentially killing your motor..
Old Jun 17, 2008 | 06:18 AM
speedooo's Avatar
Default Re: JDM 1.5 SOHC Vtec (1CaMw0nDeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CaMw0nDeR &raquo;</TD></TR><TR><TD CLASS="quote">
lol why did u set vtec at 3700 and redline at 9300..??? u kno on a dyno chart ur peak power is gonna start to drop way before that so all you're doing is potentially killing your motor.. </TD></TR></TABLE>
not to mention engaging vtec so low makes you LOSE power down there and the powerband of that motor dies at 7k
op-
Old Jun 19, 2008 | 01:52 AM
Default Re: JDM 1.5 SOHC Vtec (speedooo)
i dont bring it to 9300 ha i shift at about 8400
Old Jun 19, 2008 | 08:53 AM
speedooo's Avatar
the stock rev limiter is <U>7200</U> for a reason, christ a b16's rev limiter is lower than where you shift
Old Jun 19, 2008 | 09:13 AM
honda22hannah's Avatar
Default Re: JDM 1.5 SOHC Vtec (*****sTaH)
actually the D15 is higher compression, its 9.5 to 1
and its 130hp vs. 125 for the z6
and the rev is 7200 - i miss that motor actually, felt faster than my current z6
Modified by honda22hannah at 10:46 AM 6/19/2008
Old Jun 19, 2008 | 09:26 AM
RIP_EJ1's Avatar
60,000ths = .060"
...please do a little more research before milling your head that much. That's quite excessive.
shosek03
Sep 21, 2007 10:20 AM
CRseXy
Jan 22, 2005 12:47 PM
South Bay Surfer
12
Nov 7, 2002 07:59 PM
bluedelsol
12
Aug 19, 2002 12:03 AM
Ted_Striker
28
Jul 7, 2002 07:58 PM
