Stock GSR Turbo Setup
Old Jun 16, 2008 | 09:37 PM
b20vcrxsir's Avatar
Default Stock GSR Turbo Setup
I have a 1996 B18C1 in my 1991 Honda CRX Si. The motor is stock, except for the Skunk2 intake manifold and 68MM Throttle Body. I am getting a P FAB Manifold ( log style), precision turbo (GT35R), Tial Wastegate (38MM), Greddy BOV (Type RS), spearco intercooler (27x7.5x2.5) and 2.5" downpipe (5 Bolt Patern). I am planning on boosting 10-12 psi.
Will this be safe for a stock motor?
Is the setup above any good?
If not, what would you change?
What HP do u think I should be expecting?
Please post similar setups and the power they made.
Old Jun 16, 2008 | 10:14 PM
mtber's Avatar
Default Re: Stock GSR Turbo Setup (b20vcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1996 B18C1 in my 1991 Honda CRX Si. The motor is stock, except for the Skunk2 intake manifold and 68MM Throttle Body. I am getting a P FAB Manifold ( log style), precision turbo (GT35R), Tial Wastegate (38MM), Greddy BOV (Type RS), spearco intercooler (27x7.5x2.5) and 2.5" downpipe (5 Bolt Patern). I am planning on boosting 10-12 psi.
Please post similar setups and the power they made.</TD></TR></TABLE>
The b18c1's weakest point is going to be it's ringlands.
Make sure you get some good fuel management such as Hondata, Ectune, Neptune. Otherwise your motor won't last a single pull.
You may want to also consider pistons/rods to be able to really enjoy the gt35 :-)
Old Jun 17, 2008 | 12:32 AM
quik sol's Avatar
gt35r is overkill for a stock internal gsr's limits.
If you want a gt series, atleast back down to a gt30
Old Jun 17, 2008 | 09:21 AM
syzurs1's Avatar
that turbo is way to big for only 12lbs. the turbo will barely breath at that boost level. plus, the gt35r will put a big hole in your pockets. i've seen power levels at 300+hp with a good tune.
Dat_Hatch
May 5, 2014 09:39 AM
Dat_Hatch
Apr 30, 2014 02:22 PM
aRandy
Jun 2, 2010 10:52 AM
null.
Aug 7, 2004 08:48 AM
hybridreams
Feb 3, 2003 03:55 PM
