Rattle sound from belt area on ep3
Old Jun 16, 2008 | 06:55 PM
tyrone's Avatar
Default Rattle sound from belt area on ep3
http://uk.youtube.com/watch?v=yiCujw554Ok
http://uk.youtube.com/watch?v=cVsZaKmVnZc
I been getting a rattling sound coming from the left side of the engine... it sounds like its coming from the belt area or underneath there.. i tried spraying some wd40 around the top two belt pulleys i think one is the belt tensioner as someone suggested on another forum... but it did not resolve the issue...
any ideas? Please see the videos
Modified by tyrone at 8:38 PM 7/10/2008
Old Jun 17, 2008 | 09:54 AM
tyrone's Avatar
Default Re: Rattle sound from belt area on ep3 (tyrone)
bump any ideas anyone???
Old Jun 17, 2008 | 05:06 PM
WhiteOnRice's Avatar
When does it make the noise? I'd say it's the passenger mount. Did you check/tighten the pulley bolts?
Old Jun 17, 2008 | 06:38 PM
tyrone's Avatar
Default Re: (WhiteOnRice)
it makes the noise when its at idle..... and when i rev it it gets a little louder..... So u think i should try to tighten all those nuts that hold the belts ???
Old Jun 17, 2008 | 07:36 PM
I really doubt it's a loose pulley. It would have probably fallen off if it's loose at all. Stock exhaust? Check your heat shield.
If it does it at idle just listen/look around until you find the noise.
Old Jun 18, 2008 | 03:11 PM
tyrone's Avatar
hey white on rice thanks for your help so far...
i put my car up on ramps... let the car run and tried to look from the sound... it sounds like its coming from the very bottom pulley... I notice that pulley spins it doesnt look quite straight.. like if you look from above it looks like it moves a little wobbly... You know like if a wheel is not centered it will wobble? It looks sort of like that.... But hte belt is on there straight....
I dont know if that is a big deal or not.. i think i give up... as long as its safe i'll just leave it.....
Old Jun 21, 2008 | 06:28 PM
ricardo_achata's Avatar
Default Re: (tyrone)
i had the same problem, take a good look to the pulleys. i had to replace the water pump the wheel was kinda loose, not noticable by the eye but if you spin it youll notice the sound. jack the car, loose the ac belt and check every pulley, im sure that its the water pump, let me know how that go
Old Jun 23, 2008 | 10:45 PM
I'm curious if you figured this out.
Old Jun 24, 2008 | 03:27 PM
tyrone's Avatar
sorry havent gotten it figure out.. it sounds like its coming from the very bottom pully gear thingie.. i have no idea how to even adjust it or what not.....
i tried just putting a socket on it and turning it but it just turned the whole wheel and belt...
so i just been driving around with the noise... its sorta loud...
Old Jun 26, 2008 | 05:40 PM
I really, really, REALLY doubt it's the crank pulley. Keep looking.
If you still think it's a pulley, take the serpentine belt off completely and spin all pulleys but the crank pulley (lowest). It could be the water pump like ricardo_achata
said. That pulley doesn't have the grooves in it or a nut holding it on; it kind of looks like a cam gear.
Other things to check: heat shields, motor mounts, entire suspension, etc.
Old Jun 30, 2008 | 08:49 PM
tyrone's Avatar
wait yea thats the one i was thinking it was... the wheel that doesnt have a nut holding it on... and its the most bottom and rear of all those gears.....?!
anyways i havent climbed under there.. its still making that sound.... how long do you think before my car starts having real problems and i get stranded on the side of the road??? I'm guessing i'm gonna have to take it to a mechanic to get it fixed because it looks like its real complicated under there...
Old Jun 30, 2008 | 08:58 PM
FrankinDC5's Avatar
Get your car on jacks, remove the pass side wheel and then remove the lining that runs under the motor into the inner wheel well. The pulleys will be exposed for the most part and you can see exactly where it's at.
Have a buddy kinda rev the engine a little so you can pin point where the sound is.
Old Jul 1, 2008 | 02:09 PM
tyrone's Avatar
Default Re: (FrankinDC5)
i did that sorta.. got the car on ramps... looked under that area and pulled the plastic lining to the side.... it sounds like its the bottom back wheel thingie..... Anyways if it is that one.. i would have no idea how to fix that........
Old Jul 3, 2008 | 07:37 AM
Please just remove your serpentine belt and spin the water pump pulley by hand. Diagnose by elimination.
Old Jul 3, 2008 | 03:00 PM
jdmkid91706's Avatar
is anyone willing to sell some 03 ep3 wheels??????
Old Jul 3, 2008 | 04:16 PM
Here are some: https://honda-tech.com/zer...
Old Jul 5, 2008 | 01:16 PM
tyrone's Avatar
Default Re: (jdmkid91706)
sorry jdmkid91706. I decided to keep my stock wheels... sorry homie....
Old Jul 10, 2008 | 12:02 PM
tyrone's Avatar
Here are videos i took today of the rattling sounds....... you can hear the rattling pretty good on both videos... any ideas???
Old Jul 11, 2008 | 09:46 PM
Ekkkk, sounds internal.
Old Jul 12, 2008 | 04:02 AM
teamko's Avatar
That shounds like your valves are Wrapping!!!! You have bad gas or have raced the engine lately or had someone adjust the valves that didnt' know what they were doing. Valves are my choice...Don't drive it
Old Jul 12, 2008 | 01:55 PM
tyrone's Avatar
Default Re: (teamko)
ok so what should i do? Take it to a honda mechanic??? I just bought the car very recently with 118k miles on it...... perhaps a valve adjustment may resolve this?? I guess the 120k service should be coming up real soon too.... Perhaps doing the 120k maintenance service and valve adjustment???
I havent put any bad gas in it as far as i know and i definately had not raced it...
The car itself runs perfectly fine, it idles smoothly..... Just its a real annoying sound..... and i dont want any major damage to occur.. so if anything preventitive can be done...
Modified by tyrone at 3:51 PM 7/12/2008
Modified by tyrone at 4:35 PM 7/12/2008
Old Jul 12, 2008 | 11:09 PM
Valve adjustment: http://www.vtec.net/articles/v...43824
looopson
May 26, 2011 10:26 PM
teamvirus
Honda Civic (2001 - 2005)
Jun 1, 2009 06:49 AM
GSRpoweredSI
Jun 20, 2007 01:13 PM
pbizzlegsr
Mar 1, 2004 05:09 PM
-iLLuZioN-B18C1
Jan 8, 2003 06:16 PM
