water temp???
Old Jun 16, 2008 | 05:45 PM
19992civichatch's Avatar
Default water temp???
whats up honda-tech im doing a 0bd1 b16 swap in my 1991 crx im using a ob0 engine harness. my problem on the obd0 harness the plug for the water temp is differnt then the water temp senser. im going to wire in the right plug but im not sure witch wires are on what side of the senser. the color of the wires are yellow with a green strip, and black. thank you
Old Jun 16, 2008 | 06:46 PM
black0hatch's Avatar
Default Re: water temp??? (19992civichatch)
your doing something wrong the plugs are all the same for the temp sensor and the temp guage sensor. the only plug that is different witch is probably what your talking about is the fan switch. you gota extend those wires to reach the thermostat housing if you got a obd1 motor. and it doesnt matter witch wire goes to witch wire it will work either way.
Old Jun 17, 2008 | 12:51 AM
bobjohnson's Avatar
Default Re: water temp??? (black0hatch)
if you wire them backwards the fan will spin backwards.
Im going to assume as in most things electrical, black is negative, the colored wire is positive.
Old Jun 17, 2008 | 08:46 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch &raquo;</TD></TR><TR><TD CLASS="quote">whats up honda-tech im doing a 0bd1 b16 swap in my 1991 crx im using a ob0 engine harness. my problem on the obd0 harness the plug for the water temp is differnt then the water temp senser. im going to wire in the right plug but im not sure witch wires are on what side of the senser. the color of the wires are yellow with a green strip, and black. thank you</TD></TR></TABLE>the connector you are talking about is the cooling fan switch - it doesn't matter which wire is where - it is just a switch in the negative ground wire - when coolant temp is cold the switch is open and the ground is open - when coolant gets up to operating temperature, the switch closes completing the ground circuit causing the fan to run
Modified by jlicrx at 10:51 AM 6/17/2008
Old Jun 17, 2008 | 08:54 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote"> the plugs are all the same for the temp sensor and the temp guage sensor. </TD></TR></TABLE>not quite - the temp sensor for the ECU has a 2-wire connector - the sensor for the gauge has a 1-wire connector
Old Jun 17, 2008 | 06:16 PM
Default Re: water temp??? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson &raquo;</TD></TR><TR><TD CLASS="quote">if you wire them backwards the fan will spin backwards.
Im going to assume as in most things electrical, black is negative, the colored wire is positive.</TD></TR></TABLE>
thats not true at all you dont know what your talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">not quite - the temp sensor for the ECU has a 2-wire connector - the sensor for the gauge has a 1-wire connector</TD></TR></TABLE>
i meant the plugs between the engine harness and the motor.
Old Jun 17, 2008 | 10:43 PM
crazzymad's Avatar
its the fan switch and it will only work 1 way so it doesnt matter which way u wire it coz if it dont work the one way must work the other
Old Jun 18, 2008 | 07:44 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">i meant the plugs between the engine harness and the motor.</TD></TR></TABLE>
Old Jun 18, 2008 | 08:18 AM
i was takin about the 2 wire plug on the obd0 harness thats in back of the motor to a 0bd1 water neck houseing is that right?
Old Jun 18, 2008 | 08:41 AM
jlicrx's Avatar
Default Re: (19992civichatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch &raquo;</TD></TR><TR><TD CLASS="quote">i was takin about the 2 wire plug on the obd0 harness thats in back of the motor to a 0bd1 water neck houseing is that right?</TD></TR></TABLE>that is right - the cooling fan switch is on the back of the block on the OBD0 engines and on the thermostat housing on the OBD1 engine - yellow/green and black wires - doesn't matter which wire goes where as it is just a switch to ground
Old Jun 18, 2008 | 09:01 AM
sgallagher's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">that is right - the cooling fan switch is on the back of the block on the OBD0 engines and on the thermostat housing on the OBD1 engine - yellow/green and black wires - doesn't matter which wire goes where as it is just a switch to ground
correct.
Old Jun 24, 2008 | 06:53 AM
lapulapu's Avatar
Why dont you just switch out the Coolant Fan Switch from a two prong to a single prong fan switch? btw, would any of you know what size socket used to remove the double prong fan switch?
garyc17
Sep 6, 2008 08:30 PM
garyc17
Sep 6, 2008 07:43 PM
teler86
Nov 1, 2006 03:14 PM
zccr-xsi
11
Feb 20, 2006 04:11 PM
untitled
Aug 27, 2003 12:54 PM
