weird Cooling problem after HG
Old Jun 16, 2008 | 02:32 PM
dog2525's Avatar
Default weird Cooling problem after HG
All right guys, I am having a weird cooling problem. This is what happened. One of the taps on the radiator cap broke, let in air in the cooling system and overheated the engine, causing a blown head gasket. Replaced it with a new D series all metal head gasket and a timing belt change. After doing the head gasket replacement, there is no pressure on the radiator hose. The temp gauge doesn't move at all, and after running for couple of minutes, the radiator gets blazing hot. The fan kicks in and everything, but i am worried. anyone encounter anything like this? Scared, and am not driving it in till i figure this out.
Old Jun 17, 2008 | 01:04 PM
dog2525's Avatar
anyone experienced something like this?
Old Jun 17, 2008 | 01:08 PM
D16SiHatch's Avatar
Default Re: (dog2525)
did you properly bleed the system of air bubbles? did you follow all torque specs for tightening the head down?
sgallagher's Avatar
Default Re: weird Cooling problem after HG (dog2525)
Which radiator hose are you referring to? The top hose should get hot. The lower hose coming from the t-stat will not get hot until the t-stat opens. Did you replace your thermostat?
Old Jun 17, 2008 | 01:17 PM
dog2525's Avatar
system was bleed, and everything was torqued down to specs. As for the hoses, the top one has no pressure, you press on it and its like empty, and the radiator is very very hot. Never felt one that hot. the thermostat was fine before the HG change. I guess i should replace that and see.
Old Jun 17, 2008 | 01:23 PM
sgallagher's Avatar
Default Re: (D16SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">did you properly bleed the system of air bubbles? did you follow all torque specs for tightening the head down?</TD></TR></TABLE>
Good point about the bleeding. Except the air will get much hotter than the coolant/water if the air pocket is around the temp sensor it will cause the gauge to read very hot when in fact it is not.
Old Jun 17, 2008 | 01:26 PM
sgallagher's Avatar
Could be a problem with your water pump not circulating as efficiently as possible. You should always replace it when you change your t-belt.
Old Jun 17, 2008 | 01:30 PM
dog2525's Avatar
the funny this about the timing belt was when putting the head back on, something fell inside the cover and got caught. After taking it out, we saw the belt ripped a bit so we changed it. Motor was build 60 thousand miles ago, and did not see a point in changing the pump. Maybe I should have.
Old Jun 18, 2008 | 10:57 AM
dog2525's Avatar
just changed the thermostat and same story. bleed the system again and same thing.
Old Jun 18, 2008 | 02:14 PM
cr-x-91's Avatar
the radiator cap is what creates pressure, im thinking u could have a bad water pump. The impeller isn't creating flow. Whenever u change the belt,its a good time to replace the wp, peace of mind u know.
Old Jun 18, 2008 | 02:18 PM
sgallagher's Avatar
Default Re: (cr-x-91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 &raquo;</TD></TR><TR><TD CLASS="quote">the radiator cap is what creates pressure, im thinking u could have a bad water pump. The impeller isn't creating flow. Whenever u change the belt,its a good time to replace the wp, peace of mind u know.</TD></TR></TABLE>
The radiator cap does not create pressure. It only regulates pressure by releasing if necessary.
Pump creates flow, restrictions create pressure, cap regulates pressure.
A higher pressure cap allows the cooling system to operate at a higher pressure therefore causing a higher boiling point.
Old Jun 18, 2008 | 02:28 PM
cr-x-91's Avatar
NO, your wrong. The cap is one of the main restriction in the system. The pressure it creates raises the boiling point of the cooling system 3 degrees for every pound of pressure.
tnhzvh96
Dec 14, 2015 10:48 PM
slamLOWnBANGIN
43
Feb 28, 2010 06:01 AM
superstock2
15
Sep 1, 2006 09:44 AM
B17AGSR
Jun 8, 2004 07:23 AM
Soled Out
Nov 24, 2002 06:57 PM
