Vtec problem!!!
Old Jun 16, 2008 | 09:28 AM
integraluva04's Avatar
Default Vtec problem!!!
i have a problem going into vtec. i have a 96 gsr with a chipped 93 gsr computer. when i go into vtec it like hesitates. like goes in and out of vtec. tried: swapped to known good ecu, swapping dist, swapping vtec solenoid. my motor is a semi built b20/vtec.
Old Jun 16, 2008 | 10:49 AM
vtecb18c's Avatar
Default Re: Vtec problem!!! (integraluva04)
make sure your not low on oil and your getting enough fuel pressure
Old Jun 16, 2008 | 11:03 AM
i've checked both
Old Jun 17, 2008 | 03:23 PM
eg6sirll's Avatar
Default Re: (integraluva04)
coolant temp sensor or wiring thats bad can cause this as well
you replaced the distributor did you set the timing correctly??
Old Jun 18, 2008 | 05:32 AM
King V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraluva04 &raquo;</TD></TR><TR><TD CLASS="quote"> my motor is a semi built b20/vtec. </TD></TR></TABLE>
I would shitcan the chipped ECU and get it properly tuned.
DarikDisease
Aug 26, 2008 01:29 PM
ilovemyb16a
12
Sep 7, 2006 10:07 AM
J's GS-R
Feb 21, 2006 09:13 PM
b19coupe
Sep 3, 2003 07:02 PM
