What endlinks to use with Function 7 LCA 's (Lower control arms) ???
First off, I have a 2000 Civic si and I've had an ASR kit laying around which consists of ASR SUbframe reinforcement, ITR sway bar, and endlinks. I just ordered some FUnction 7 LCA's and I heard that the F7 endlinks have too much clinging and that OEM endlinks don't work with the F7 LCA's. Anyone run this set up? If so, what endlinks would you suggest?
I use the F7 endlinks with nylon washers between where parts make contact. No clanging for 2 years.
The noise youre referring to will happen with ANY endlink of similar design, however. Thats just the nature of the beast.
They will not, as far as i know - the design is too different. EM1 or CRV endlinks are the only oem option, and theyre too short.
Really, nylon washers do the trick just fine. I have no complaints and its on my DD
asr endlinks will work perfectly with the f7 lcas. i have them too. i have 2 extra pairs of bnib asr endlinks in my closet. let me know if you're interested.
Agent_EM1
Suspension & Brakes
Jun 20, 2008 06:59 PM
