b20 build
ok so my trans grinds in 3rd gear. How much does it cost to fix that? im also planning on gettin pistons and rods. Whats this i hear about gettin it bore and sleved? what does that do and how much would that cost?
costs about 1500 to fix the trans and getting it bored means bigger displacment which means more power...it also depends on the shop that your getting it done at when it comes to the price...make sure you research places to insure good work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duyfash0 »</TD></TR><TR><TD CLASS="quote">ok so my trans grinds in 3rd gear. How much does it cost to fix that? im also planning on gettin pistons and rods. Whats this i hear about gettin it bore and sleved? what does that do and how much would that cost?
Well the stock b20 sleeves are thin. Alot of people get it sleeved so they can run high boost. Getting it sleeved will run you anywhere between 800-1500 bucks. ya dont have to get it sleeved. If ya are running it N/A then ya should be fine. Only time ya usually run into problems with the b20 sleeves and when ya boost them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c »</TD></TR><TR><TD CLASS="quote">costs about 1500 to fix the trans </TD></TR></TABLE>
Where the hell are you getting your trannys fixed? You can buy a used one for a couple hundred bucks.
</TD></TR></TABLE>Well the stock b20 sleeves are thin. Alot of people get it sleeved so they can run high boost. Getting it sleeved will run you anywhere between 800-1500 bucks. ya dont have to get it sleeved. If ya are running it N/A then ya should be fine. Only time ya usually run into problems with the b20 sleeves and when ya boost them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c »</TD></TR><TR><TD CLASS="quote">costs about 1500 to fix the trans</TD></TR></TABLE>
yep. check out gear speed cause they got good deals and can customize it for you.
http://www.gearspeedinc.com
So i can get piston and rods and i dont have to get my bottom sleved at all as long as i dont go turbo? would it be safe still? forgot to mention i have a type r tranny also
