clutch cable too short after swap
Old Jun 15, 2008 | 09:12 PM
Nutnwrench's Avatar
Default clutch cable too short after swap
I recently swapped a D15B into my 91 CRX HF and I used the hasport mount and hydro to cable manual conversion kit. The trouble is now the clutch cable is at max ajustment and the clutch isn't fully released no matter how I route the cable. Is the clutch cable in an Integra longer than the EF, or any other Honda for that matter? I need about 2 inches longer to put it in the middle range of adjustment.
Old Jun 16, 2008 | 09:57 AM
vtecb18c's Avatar
Default Re: clutch cable too short after swap (Nutnwrench)
90 integra cable should work
Old Jun 17, 2008 | 11:34 AM
1kreationz401's Avatar
no you could use the crx clutch cable you just got to do a lil adjustment to it.
on the clutch cable above the turning **** you gotta cut out 1 in and a half where you'll see the white cable and cut off the metal trim wires. after that you'll be able to adjust the clutch.
Old Jun 17, 2008 | 02:06 PM
Nutnwrench's Avatar
Default Re: (1kreationz401)
The purpose of me asking on this post though was to find something that looked good, not all ghetto rigged. Thanks Vtecb18c I'm looking into an Integra one now and from the way it's described it is longer.
Old Jun 17, 2008 | 02:32 PM
SIred91's Avatar
Rainman
Default Re: (Nutnwrench)
Yes, use the B series cable.
Old Jun 17, 2008 | 04:34 PM
flatblackfury91's Avatar
Default Re: (SIred91)
you should be able to adjust it out woithout cutting or any other butchering. i did it on mine. pull the clutch fork up and just stick it in.
Old Jun 17, 2008 | 08:23 PM
91redrex's Avatar
Default Re: (flatblackfury91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatblackfury91 &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to adjust it out woithout cutting or any other butchering. i did it on mine. pull the clutch fork up and just stick it in.
hes right cuz i just did a h22 swap with hasport kit and it fit fine.....never heard of that...??
Old Jun 18, 2008 | 08:55 PM
Default Re: (91redrex)
thanks for backin me up. nice rex btw
alexdog69
43
Jan 26, 2012 07:22 PM
slayerP
Apr 5, 2008 01:34 PM
mjfubar101
Dec 25, 2007 08:20 PM
1RMDave
Jan 27, 2006 04:33 AM
