proportioning valve
Old Jun 15, 2008 | 04:37 PM
everythingwentblack's Avatar
Default proportioning valve
i just put on a full gsr brake set up, and my question is can i pull the prop valve off the gsr and use it properly? its a 93 with abs, I didnt know if a 4040 prop valve from an integra with abs would be compatible with a non abs 94 civic coupe. I just spend an hour trying to find out the answer but to no avail. Im sure someone will say "your such a noob you [freak]in idiot, it wont work use this" but Im okay wtih that since it answers my question haha
Old Jun 15, 2008 | 04:43 PM
jetmech53's Avatar
Default Re: proportioning valve (everythingwentblack)
I just put a 00 GSr setup on my 94 civic sedan. From my research you need to use a proportioning vale from a 90-93 integra non abs. By using this valve it also makes it a direct bolt in for the 30/30 valve most 92-95 civic's have. The exception is the bracket is not the same. if you check out some of the other forums you'll find out this info too. hope this helps. non-abs car pre-mod
abs valves are a different style and do not have the correct hook ups. 6 connections are required for non-abs cars
Modified by jetmech53 at 5:48 PM 6/15/2008
Old Jun 15, 2008 | 05:05 PM
r3vmixman's Avatar
You should be fine using the 40/40 prop valve.
Old Jun 15, 2008 | 05:07 PM
so your sayin a 4040 prop valve from a 94 non abs intera would not work? go with a 90-93 non abs prop valve?
Old Jun 15, 2008 | 05:16 PM
jetmech53's Avatar
Default Re: (everythingwentblack)
The 90-93 was easy for me to locate. If yours is a 6 port, and it has 40/40 stamped on it, you should be ok. The bottom line is NON-ABS, 40/40 valve.
Old Jun 15, 2008 | 06:52 PM
r3vmixman's Avatar
Dude sorry for the misinformation. Just found out u actually need the prop valve from an eg as well as the front left and right brake lines from an eg. Everything else should be fine.
dblock8989
Apr 25, 2016 03:55 PM
ZCHondaCRX91
Suspension & Brakes
Feb 4, 2012 09:18 PM
Mattcuzko
May 15, 2011 09:54 PM
Ej8_KiD
Suspension & Brakes
Apr 2, 2011 07:06 PM
98silverhatch
Sep 27, 2002 02:26 PM
