ATS 4.929 Final Drive/Nitrous
How do people think these will work out together? The reason I ask is because nitrous already makes the car rev fast, and I may be using the nitrous in first gear (not sure yet). Is this one of the ATS gear sets that only affects gears 2, 3, 4? or which ones?
any info on pricing?
Jon
Jon
This FD is NOT a mod designed for 1/4 mile drag, and Certainly NOT for a happy gas combo.
This FD will effect ALL of your gears ratio's essentially Making them even shorter/tighter than stock, so It wouldn't let you take any advantage of the gas. You'd blow through gears and waste time shifting.
A final drive affects all gear ratio's. So 1-5 will be altered. With the ATS FD the engine will be 1000 rpm higher at the same vehicle speed as stock.
ten bucks says he goes and does it anyway, no matter how many smart people tell him "no".
to big of a FD. Your best bet would be a gsr or b16 tranny and juice the **** out of it....... less wheel spin......
And wouldn't there be MORE wheel spin cuz theres no LSD?
