need help bleeding hydro clutch on 93 del sol si
Old Jun 15, 2008 | 10:01 AM
ximportman's Avatar
Default need help bleeding hydro clutch on 93 del sol si
need help guys bleeding the clutch on a 93 sol si, pumped the clutch a few times and undid the bleeder screw and now the pedel stays at the floor, is there any thing special i have to do with bleeding and adjusting the clutch on a hydro tranny?
Old Jun 15, 2008 | 10:29 AM
jadziasman's Avatar
Default Re: need help bleeding hydro clutch on 93 del sol si (ximportman)
You need a one man brake bleeder kit to do this properly. Harbor Freight sells a cheap one that works good. Get yourself a pdf manual and you should have no problem.
http://hondatech.info/downloads/Auto/Manuals
Old Jun 15, 2008 | 10:42 AM
z6hatchboy's Avatar
the reason it went to the floor is because when you loosened the bleeder it let the fluid and pressure out (and any air that was in it), to regain pressure, add fluid if needed and pump clutch again. It helps to have so friend so one can pump and hold and the other can use the bleeder
Old Jun 15, 2008 | 10:45 AM
ximportman's Avatar
ya i had a friend help me do it, and we prolly pumped and bleeded it 40 times and after every time we bleed it, he had to actually pull the clutch pedel up from the floor to pump it again
Old Jun 15, 2008 | 10:50 AM
z6hatchboy's Avatar
Default Re: (ximportman)
Thats how mine was when i did it but i dont know if i did it like 40 times, if you know your slave cylinder is good then its just a matter of pumping it more assuming you have no leaks and stuff.
Old Jun 15, 2008 | 11:50 AM
turboteg90's Avatar
pm for noodz
Default Re: (z6hatchboy)
i recently bleeded the clucth by my self,i just pumped the pedal and put a huge rock on it so it would stay on the floor,then i went and lossen the cylinder,i did this like 3 times and it worked.
Old Jun 15, 2008 | 12:11 PM
shadhman's Avatar
I had the same issue.. turns out my master cylinder went bad :S Follow your clutch pedal up underneath your dash and see how things look there. Also like someone else stated your slavecylinder could be bad but lets not jump to conclusions.. try a using a mity vac.. if still no dice returnd the mityvac and start trouble shooting
BedDeMoN
Apr 1, 2009 03:42 PM
BaronVonZ
May 22, 2008 07:48 PM
dynastix9
Jan 13, 2006 01:33 PM
gvrules
Jan 16, 2005 03:26 PM
DelSol808
Aug 3, 2002 05:32 PM
