Head Gasket Question
Old Jun 15, 2008 | 10:00 AM
94sihatchy's Avatar
Default Head Gasket Question
I recently purchased a sleeved gsr block...sleeved to 2.0 the problem i am having is i am planning on putting a b16 head on and i am confused as to which head gasket to use and if i can get a cometic one. If anyone knows which head gasket to use that would help me out greatly. Thanks!!
Old Jun 15, 2008 | 11:48 AM
inspyral's Avatar
B series VTEC head gaskets are the same, so it doesn't matter which one you use as long as you match your bore diameter. You can run a Cometic MLS gasket, but most people prefer OEM Honda gaskets. Golden Eagle sells OEM Honda gaskets bored out to whichever diameter you need(84mm in this case).
Old Jun 15, 2008 | 12:40 PM
94sihatchy's Avatar
Default Re: (inspyral)
Thanks you have helped me out alot!
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
Joeski99Si
Apr 23, 2009 05:24 AM
Joeski99Si
Apr 22, 2009 09:57 PM
onlinehost
Nov 14, 2005 08:14 PM
92civic2004
May 7, 2004 03:00 PM
