how to remove NRG slim hub?
i just put on the NRG slim hub a few weeks ago and need to adjust it but can get it off for the life of me, i went to autozone and rented a wheel puller but the hub doesnt have the 2 holes to screw into like a stock steering wheel does?!?! so my question is how have you guys in the past removed your NRG slim hubs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n0rmaL »</TD></TR><TR><TD CLASS="quote">i just put on the NRG slim hub a few weeks ago and need to adjust it but can get it off for the life of me, i went to autozone and rented a wheel puller but the hub doesnt have the 2 holes to screw into like a stock steering wheel does?!?! so my question is how have you guys in the past removed your NRG slim hubs?</TD></TR></TABLE>
depending on car, there should be a 19mm nut that holds the hub in place. Did you remove that first?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asiandoood »</TD></TR><TR><TD CLASS="quote">depending on car, there should be a 19mm nut that holds the hub in place. Did you remove that first??</TD></TR></TABLE>
yea for my car its a 14mm bolt and yes i removed it.
take the nut holding the hub off bolt your wheel back to it, and pull. HARD. that's how i've pulled stock honda wheels and thats how i pull my aftermarket ones off too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PornoPanda »</TD></TR><TR><TD CLASS="quote">take the nut holding the hub off bolt your wheel back to it, and pull. HARD. that's how i've pulled stock honda wheels and thats how i pull my aftermarket ones off too.
yea thats how i pulled the stock one off too, and i did what you just said, took off the bolt and bolted the wheel back on, and i pull with all my might! but it didnt budge
i guess when i torqued the bolt on it some how locked the hub in place or maybe i need a stronger person to pull it for me haha
</TD></TR></TABLE>yea thats how i pulled the stock one off too, and i did what you just said, took off the bolt and bolted the wheel back on, and i pull with all my might! but it didnt budge
try wiggling it back and forth like someone said, not trying to pull it straight off cause it wont come off that way, my buddy has the NRG slim hub also and he tried pulling it straight out and it didnt budge but when you wiggle it back and forth while pulling it came off easy. good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by battle951sedan »</TD></TR><TR><TD CLASS="quote">put ur wheel back on and wiggle it. top part and bottom part of the wheel. it should come off in a few seconds. </TD></TR></TABLE>
that sure did the trick, thanks for the advice!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkTegi »</TD></TR><TR><TD CLASS="quote">is that a monte carlo wheel??</TD></TR></TABLE>
yes indeed
yes indeed
metalgears
Jul 25, 2004 12:08 PM
SIR Spooner
Mar 8, 2004 07:50 PM
