Weak engine power at low RPMs
Old Jun 14, 2008 | 02:31 PM
jccrews90's Avatar
Default Weak engine power at low RPMs
I recently did a swap in my '92 Civic Si, and at lower RPMs (below 2-2.5k) the engine seems to be very weak. Usually moving very slow, but once the RPMs get over 2k the power kicks in and runs fine. I found that I can rev the engine to about 2.5k, and take off fine. I have a B18C1 ('98 GSR) block with Type-R internals and a B16A2 ('00 Civic) head (or Poor man's Type-R for short). Any advice is appreciated, thanks!
Old Jun 14, 2008 | 07:17 PM
batallic's Avatar
Default Re: Weak engine power at low RPMs (jccrews90)
thTS because of low amount of torque
Old Jun 14, 2008 | 08:39 PM
jccrews90's Avatar
No, that's not the case. I can push the pedal to the floor at lower RPMs and there is no movement, just an idle roll. A friend of mine said to check into my IAC Valve. Could that be the problem?
Old Jun 14, 2008 | 10:01 PM
Urban_Honda's Avatar
i have the same problem with my 97 hx. It has the factory hx ecu but with a non-vtec ex motor. no power at all till i get it reved up over 3k, i cant ever run the ac or it will idle at 400 rpms at a red light. it also has a check engine code for the air/fuel sensor, so it COULD b either one of those
Mangudai
Jun 1, 2010 04:45 PM
mr. goodwrench
Nov 17, 2008 04:35 AM
Drivin High
10
Sep 1, 2007 08:43 PM
Batoutahell
May 7, 2003 04:26 AM
b18civic
Apr 22, 2002 07:20 PM
