how to convert a p28 ecu auto, to a manual tranny ecu
i have a d16z6 engine manual tranny and i bought this car from a lady, but it has a auto tranny ecu p28 ,, and that results in my check light goes on.. all the time.. stays on , the code it gives me is 19 which that code is only for the auto tranny. so need some help and if someone have pics of how to do it, thanks.
i tried searching for the thread i remember reading on how to do it, but i couldnt find it... i know that you must run a jumper wire from one area to the other... sorry i couldnt be more help
edit -- found a couple of links
https://honda-tech.com/zerothread?id=708770
https://honda-tech.com/zerothread?id=2229847
Modified by riceburnerryan at 2:21 PM 6/14/2008
on the bottom right of ecu there is a set of resistors RP17 and RP18 remove both of them and just solder a piece of wire across RP17
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iknited1 »</TD></TR><TR><TD CLASS="quote">on the bottom right of ecu there is a set of resistors RP17 and RP18 remove both of them and just solder a piece of wire across RP17
Incorrect. Remove rp18 & rp17 & solder a jumper on rp18.
This is explained on our ecu chipping video tutorial on http://www.phearable.net/tech
</TD></TR></TABLE>Incorrect. Remove rp18 & rp17 & solder a jumper on rp18.
now lets say that i do that!! will my car pass the emission test tho, i live in california and you know how it is!!
and also will this change affect the vtec system?
Modified by sorullo at 1:17 AM 6/15/2008
Sry to bump an old post but i was wondering if you could re-direct me to an exact link to a video or how to on how 2 make a auto tranny into a manual tranny ecu I couldnt find it
