leaking headgasket
Im leaking a lil bit of oil above the header from the head I assume. I think its cause the head bolts have been torqued 2 many times(5 times exactly). What do u guys think? It seems to b affecting the idle a lil. Im not getting any coolant in the oil or anything and compression is 210 across the board
if your using stock head bolts they may have stretched, get some brake cleaner and clean as much of the head as you can and try to find exactly where the oil is coming from, could have bad o rings on dizzy, cam seals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elektronsi »</TD></TR><TR><TD CLASS="quote">if your using stock head bolts they may have stretched, get some brake cleaner and clean as much of the head as you can and try to find exactly where the oil is coming from, could have bad o rings on dizzy, cam seals</TD></TR></TABLE>no its clearly leaking from the front of the head right above header, the dizzy area is clean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man honda »</TD></TR><TR><TD CLASS="quote">If it's above the header it's not the head gasket. More likely the valve cover gasket.
Exactly. You're in luck as far as the work that needs to be done.
Honda sells Hondabond that's good for sealing the corners in a valve cover gasket, but any Permatex (gray is reccomended) will do along with a new valve cover gasket, if this is the problem of course.
Old Man Honda..... 4 posts in 3 years, whereya been?
Modified by Rok_Stok at 2:15 PM 6/14/2008
Honda sells Hondabond that's good for sealing the corners in a valve cover gasket, but any Permatex (gray is reccomended) will do along with a new valve cover gasket, if this is the problem of course.Old Man Honda..... 4 posts in 3 years, whereya been?
The header is bolted to the head and the head gasket is under the head and on top of the block, in between both of them. So if the oil is comming from above the header flange it would be a valve cover leak most likely, if under the header flange it would be your head gasket most likely, since the head gasket is under the head.
But anyways, it's comming from where the block meets the head. So you may have answered your own question, it's okay I do it all the time. But, the good compression is somewhat boggling me if your head gasket is blown and leaking oil.
Rok Stok- I''ve been enjoying trouble free driving for the last 3-years, so no need to post.
Hondachris- any chance you can upload a pic for us? My experience has been that Honda's will blow the gasket between number one and two cylinders. Even then, I had no oil leakage. It was also on the intake (back) side of the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rok_Stok »</TD></TR><TR><TD CLASS="quote">The header is bolted to the head and the head gasket is under the head and on top of the block, in between both of them. So if the oil is comming from above the header flange it would be a valve cover leak most likely, if under the header flange it would be your head gasket most likely, since the head gasket is under the head.
</TD></TR></TABLE>sorry mt bad, yes its underneith the header, its where the head meets the block
Are you running DOHC or SOHC? If it's DOHC, check the cam plug as well. The leaking from there will run down the corner of the head and along the block/head area and look like a leak there.
Low vacuum testing should tell you if it's actually the head gasket.
zx2gotboost
52
Jan 8, 2006 09:03 PM
