glowshift oil sender gague + cdm oil sandwich = oil leaks
Old Jun 13, 2008 | 11:01 AM
SQ is the SQUAD's Avatar
Default glowshift oil sender gague + cdm oil sandwich = oil leaks
now for todays problem my [freak]ing gay *** glowshift oil pressure sender unit thats connected to my cdm oil sandwich leaks like a mother/ i removed it, added some teflon and tightened it real good and it still leaks. right now i wanna kill some kittens.
according to the glowshift website, the sending units is a 1/8 NPT Electrical Sender Unit. i am nut 100% sure on the holes on the cdm sadwich but my stealthmode t3 oil line kit screws into it just fine and dosent leak. belive that oilline fitting is a 1/8 npt
Old Jun 13, 2008 | 04:48 PM
i guess no one has ever ran this combo before
Old Jun 13, 2008 | 04:52 PM
CarbonizedDX's Avatar
Default Re: (SQ is the SQUAD)
Only thing I can suggest is more teflon tape, use of a copper washer (requires you to have the sender threads all the way into the adaptor) or use some form of silicon sealent on the treads as it goes in.
My ex's saturn leaked when I installed the psi sender but after re installing it with more tape and cranking it all the way into the block it stopped. On my autometer unit I have teflon tape and again the sender is screwed all the way down into the body...
Old Jun 14, 2008 | 04:09 AM
ill try more teflon tape today
Old Jun 14, 2008 | 04:27 AM
1992Si's Avatar
You should only have 2-3 wraps of teflon tape on a NPT fitting. You only need to snug it up if you tighten it to much you can crack the fitting or the housing.
Are you putting the tape on in the right direction ?
You want the tape to to follow the threads so it doesn't bunch up as you thread the fitting in.
I use teflon tape on NPT fittings at work and have no leaks at over 1200psi.
Old Jun 14, 2008 | 04:59 AM
ill make sure i take your advice. and ill report back. thanks for the pointers
Old Jun 14, 2008 | 05:42 AM
i just removed the sensor again and the teflon was all bunched up
h-t ftw
Old Jun 14, 2008 | 06:30 AM
ok, i re taped it the right directino and it still leaks. what kinda of fast drying compound can i put on the threads to seal it. i dont care if i have to use something like thread lock
Old Jun 14, 2008 | 08:54 AM
i ended up getting permatex thread sealer
Old Jun 14, 2008 | 11:06 AM
inspyral's Avatar
I like to use gasket maker like Hondabond or Permatex Ultra Black/Blue/Copper on fittings that are hard to get to once installed for extra insurance against leaks. Just make sure to clean the area thoroughly, and allow enough time for the sealant to set up before running oil through the connection or heat cycling it.
Old Jun 14, 2008 | 02:24 PM
Default Re: (inspyral)
i cleaned it real good with some brake cleaner. and i am letting it cure over nite so i wont know if it holds till tomarrow. in the mean time i poked a pin sized hole in my brand spanking new cdm dual core radiator so i am trying to figure out how am i going to patch it. ill prob just have it welded
Old Jun 15, 2008 | 09:35 AM
welfarepc's Avatar
braze it with some solder
JB weld
Old Jun 16, 2008 | 08:45 AM
this [freak]er still leaks
Old Jul 1, 2008 | 01:08 PM
LightningTeg's Avatar
Community Builder
Hey man I think I have the same problem. I have the glowshift oil pressure unit and their sandwich plate. I thought the leak was coming from the sandwich but i think its the damn sender unit. This pisses me off cause I cant figure out why it leaks no matter how I put it in or tighten it.
Old Jul 1, 2008 | 06:08 PM
fourthgenhatchB17's Avatar
Default Re: (LightningTeg)
I always use hondabond to seal threads. I have a all kinds of AN adapter fittings for my external cooler and filter and not one of them leaks.
Old Mar 6, 2009 | 08:23 PM
njebudalla's Avatar
Default Re: glowshift oil sender gague + cdm oil sandwich = oil leaks
don't use teflon on oil surfaces... that just doesn't work. Hondabond is the best. I'd recommend getting the high temp stuff from the dealer rather than the lower temp stuff. Also, there is a cool little gadget that i'd recommend rather than using the oil filter spacer. Here is the link:
http://www.tunertoys.com/TunerToys_O...et_p/otodk.htm
Anyway, beside the oil leaks... how is the accuracy of the guage?
balbowskie
Feb 17, 2012 06:47 PM
Jeffrey9
Feb 18, 2006 01:02 AM
LSVtechnologytur...
Sep 17, 2005 01:46 PM
PHOBIA
Jan 18, 2005 07:23 AM
Screamer
May 14, 2003 11:35 AM
