Harness question..........
Old Jun 13, 2008 | 09:42 AM
CivicB18C1's Avatar
Default Harness question..........
we have a 92 hatch with a gsr in it running hondata...so this means its obd1 correct? could that setup be running an obd2 harness, or does it need to be an obd1 harness?
Old Jun 13, 2008 | 09:46 AM
Fullthrottle297's Avatar
Default Re: Harness question.......... (CivicB18C1)
you will need a conversion harness so that obd2 will plug into the obd1 ecu
Old Jun 13, 2008 | 09:50 AM
CivicB18C1's Avatar
Default Re: Harness question.......... (Fullthrottle297)
so you could run the engine harness from an obd2 on the car, and also use the obd2 to obd1 jumper harness at the ecu to make it work?
Old Jun 13, 2008 | 10:11 AM
CivicSpoon's Avatar
The way you wrote the question was confusing. It sounded like you were trying to put the OBD1 hondata unit in a different OBD2 car, because you didn't add the word "engine" before the word "harness" (in your original post).
Regardless of what engine harness you use, the ECU plugs will still be OBD1, unless you take out the entire harness and put in one from an OBD2 Civic. So you won't need a conversion harness at all to run the hondata unit. And you can use an OBD1 or OBD2 Integra engine harness, both will plug right in to each other.
Old Jun 13, 2008 | 10:29 AM
CivicB18C1's Avatar
Default Re: (CivicSpoon)
alrighty, so if the motor is in the 92 civic, technically it could have a obd2 harness on it and it still would be fine to run?
Old Jun 13, 2008 | 10:53 AM
spooled-r's Avatar
Default Re: (CivicB18C1)
if its in a 92 and using hondata then it is almost certainly obd1 if some one did all that in that car w obd2 they caused them self a whole lot of extra wok they didnt need to but yes it technicaly could be obd2 to answer your question
Old Jun 13, 2008 | 05:47 PM
CivicSpoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">alrighty, so if the motor is in the 92 civic, technically it could have a obd2 harness on it and it still would be fine to run?</TD></TR></TABLE>
Absolutely.
jazzRS
Sep 28, 2012 03:16 PM
appelsos
11
Jul 11, 2011 06:24 PM
Prudz_lude
Dec 3, 2008 06:41 PM
Cuda
Jan 16, 2008 06:18 AM
TeamSTEALTH GSR
Aug 10, 2003 02:58 AM
