DRY or WET nitrous
Combustion Cycle is made of Air/Fuel and Spark. You make more power by adding to all three, but all three have to be kept in balance. If you add Air you have to add fuel. Adding Nitrous is adding Air, so you have to add Fuel as well.
Wet-Kits: Wet-Nitrous either uses it's own supply of gas or taps a fuel line and injects gasoline via an extra injector solenoid. Wet kits allow for precise fuel metering, but can strain the fuel system if they scavange too much.
Dry-Kits: Dry kits rely on "existing" Fuel sorces to provide the extra gas. Extra gas is acomplished through either increasing the fuel pressure, or having the computer add more fuel. 10 years ago Dry kits normally meant either adding fuel pressure by injecting nitrous into the fuel-pressure regulat vaccum control line or adding it via a computer modification to the ECM. Today "dry kits" typically blow through a Mass Air Flow Meter and rely on it to detect the extra oxygen and provide more gas. Advatanges: Easy to install. Disadvatages, you're asking the fuel system to do something it wasn't designed to do and that can cause problems.
For an H22 your best/safest bet is dry system.
But wet systems will give you more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Day H23 »</TD></TR><TR><TD CLASS="quote">Combustion Cycle is made of Air/Fuel and Spark. You make more power by adding to all three, but all three have to be kept in balance. If you add Air you have to add fuel. Adding Nitrous is adding Air, so you have to add Fuel as well.
But wet systems will give you more power.</TD></TR></TABLE>Damn good explanation !!
55-65 shot will be fine, but you have to get colder plugs and a fpr to regulate you fuel. if you want to go 75-100 you have to buy a ignition retard system to be on the safe side
But I have seen people here do a 75-100 shot with out retarding their ignition and been fine as long as you don't spray a lot!
GO with Zex Wet Kit!!!
Modified by shhh151 at 6:00 PM 6/19/2008
