Which cams can be run with the factory valve springs and retainers?
So far I have only found the Buddy Club Spec 3+ cams.
Are there any others?
How well do the Spec 3+ cams work?
Keep in mind all the cams that can be run on stock VT will yield subpar results in comparison to the first stages of aftermarket cams that NEED to be run on aftermarket VT...
If you're looking into cams I'm guessing that you are going for a moderate build as you are already in the actual internals. I would save up and just buy the aftermarket VT while you're at it...
