EF-1
Old Dec 7, 2003 | 08:42 AM
TurboTeG4's Avatar
Default EF-1
Does the EF-1 Valve train work well with other cams, I had m21 cams on back order but am thinking of canceling the cams and just getting the valves , springs, and retainers. I think if I wait on the cams ill wait for months more to come.
What kind of cams work well with a modified turbo b18c1, not looking for wild cams , just street good idle cams.
Old Dec 7, 2003 | 10:27 AM
earl's Avatar
Default Re: EF-1 (TurboTeG4)
I was just told that the EF-1 springs have a very high seat pressure. I think you have to be careful what cam you use with that spring.
Having said that, many here have made over 600 whp using stock gsr cams. The key seems to be short duration, lower overlap cams. The gsr cams fall into that category. Do you have the specs on the M21? Without the specs, you are buying a pig in the poke. Big cams not needed for turbo big power.
Old Dec 7, 2003 | 10:53 AM
TurboTeG4's Avatar
Default Re: EF-1 (earl)
Would the ef-1 valve train be worthy of the stock gsr cams?
Old Dec 7, 2003 | 01:09 PM
Bnjmn's Avatar
you can get by with ITR outers/portflow inners, and rocket's titanium retainers.
The rocket (used to be EF-1, now rocket) springs are more for strip cars. The spring combination I described will let you rev high and will run fine with ITR/GSR cams.
Jared's Avatar
As I remember the EF-1 valve springs have a 95lbs at the seat pressure. He garantees them to 10,500 with a 12.5mm lift camshaft(or the M24E that he sells). The M21 camshaft is similar in duration to the GSR cams with about 1.5mm more lift.
Old Dec 7, 2003 | 01:14 PM
Jared's Avatar
M21 specs per Rocket's website: 274 deg duration, 11.6mm of lift. That is for both sides. For comparison, the GSR cam has 10.6mm and 9.4mm of lift respectively.
Old Dec 7, 2003 | 02:31 PM
www.abunairacing.com
Guest
Posts: n/a
Default Re: EF-1 (Jared)
The EF-1 valvetrain is no longer called EF-1. From what i heard Rockets so called partner had some differences and split and now its call Rocket motorsports vavletrain.
Modified by www.abunairacing.com at 12:12 AM 12/8/2003
Old Dec 7, 2003 | 02:56 PM
DouLik's Avatar
Default Re: EF-1 (www.abunairacing.com)
http://www.abunairacing.com
no need for hearsay in this forum..
and from what jared said m21's
im using the valvetrain and some of my customers they all give it
Old Dec 7, 2003 | 03:54 PM
HYBRID_H@TCH's Avatar
Default Re: EF-1 (DouLik Industries)
I have been running the ef-1 (rocket motorsports) springs/retainers for close to 8 months now with not 1 problem at all..I have had..gsr,type r, and m22 cams used on these same springs with no problem..I just pulled the whole head apart to do a full; engine build up and the springs and retainers look like they are brand new.also my brother in laws car has had the same springs and retainers installed for some time on type r cams and his is working very well with no issues at all..
Old Dec 7, 2003 | 05:03 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">M21 specs per Rocket's website: 274 deg duration, 11.6mm of lift. That is for both sides. For comparison, the GSR cam has 10.6mm and 9.4mm of lift respectively.</TD></TR></TABLE>What is rocket's web site that has these specs. You need to know at what lift the duration is measured from (it's not at zero) to do a good comparison.
Old Dec 7, 2003 | 05:11 PM
DouLik's Avatar
http://www.m24x.com
Old Dec 7, 2003 | 05:33 PM
Jared's Avatar
I'm almost certain rocket measures his durations at 1mm.
Old Dec 8, 2003 | 01:27 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">I'm almost certain rocket measures his durations at 1mm.</TD></TR></TABLE>
The duration listed is gross duration.
But as you know Jared the cams make power over GSR cams.
Old Dec 8, 2003 | 01:38 PM
Rocket's Avatar
Default Re: EF-1 (Rocket)
Spring Pressure - Please Read
I know that Arturbo, Earl, and Larry Widmer are extremely knowledgeable about IC engines and such and I respect their position on spring pressure.
However, I am one of the few if only that like alot of spring pressure (notably seat pressure) and always have. The Rocket springs and retainers have zero reported failures for over the 1.5 years with various camshafts from stock, Skunk, Toda, etc. I haven't seen anyone complain yet to me or hear on H-T.
The extra seat pressure keeps things happy and provides a very good cushion for driver error. I have a friend/customer that takes his B16 to 10-11k every drive for over a year now and the head is still in one peice.
If you have the following things on your engine/car you need more spring pressure.
1. More rpm
2. More cam (specifically ramp) lift
3. Lightened Flywheel and pullyes
4. Boost
5. Higher final drive
6. More HP per cylinder (kinda goes under boost)
7. Compression braking
Most aftermarket springs are good to 10k but what about after that. I know many of you guys accidently go past that. I know of engines that blew because they exceeded 10k with other aftermarket valvetrain, but not mine.
No disrespect to anyone. Ultimately the choice of parts rest upon the engine builder and his customer and not the manufacture/distributer.
Old Dec 8, 2003 | 07:14 PM
earl's Avatar
Hi Robert. You should be in politics with that great post..haha I wish everyone was like you.
Do you think the extra seat pressure puts more wear on the stock valve train components or are they strong enough to take the extra pressure?
Old Dec 8, 2003 | 07:25 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote"> Spring Pressure - Please Read
1. More rpm
4. Boost
No disrespect to anyone. Ultimately the choice of parts rest upon the engine builder and his customer and not the manufacture/distributer.</TD></TR></TABLE>
when can i pick up a set ??? springs,retainers,valves.. do you carry valve guides?
Old Dec 8, 2003 | 07:38 PM
Rocket's Avatar
Default Re: EF-1 (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">
when can i pick up a set ??? springs,retainers,valves.. do you carry valve guides?</TD></TR></TABLE>
I reccomend OE valve guides for best service life.
PM me or my dealers.
Thanks.
Old Dec 8, 2003 | 08:13 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Do you think the extra seat pressure puts more wear on the stock valve train components or are they strong enough to take the extra pressure? </TD></TR></TABLE>
I haven't seen more wear on any parts (rockers, cam lobes, valve tips, cam caps, timing belts). I actually ask my friends/customers how their valvetrain look and all report that it looks fine.
If you think about it, 50-56lbs on the seat for stock is pretty weak and you are just inviting valve float. When the valve floats everything gets hammered resulting in mushroomed valves, retainers exploding, keepers coming loose and rubbing on the stem, the valve job gets hammered. Also too, just my theory but if there is valve float the cam and rocker can "break" thru the oil film and your worse off than running pressure. I am sure you run 100lbs on your race car for a reason. Coz you have to otherwise your cylinder head won't last.
Adding 50lbs on top of the stock seat pressure hasn't caused any premature wear from what I've seen. If the rocker or valve tip or lobe (made out of high strength steel or iron) can't handle 50lbs more on the seat and 100lbs more over the nose of the cam then the parts are shittty but fortunately they are not (not from Honda anyways).
Just glad to see that everything is cool.
Old Dec 8, 2003 | 08:55 PM
sparkz's Avatar
Just glad to see that everything is cool.</TD></TR></TABLE>
Ive been running Rocket (eF-1) Springs for about 14 months now, over 20k miles and have no reported problems with any valvetrain issues. Last I checked when doing valve adjustment show no signs of any premature wear using OEM cams and titanium retainers. Keep up the great work robert
Old Dec 8, 2003 | 10:22 PM
TurboTeG4's Avatar
Default Re: EF-1 (sparkz)
Great, just the kind of questions and answers I wanted to hear, but what about those m21 cams, any word? Im planning to start putting things together after christmas
Old Dec 8, 2003 | 10:32 PM
TurboTegB18c's Avatar
I'll be testing two sets of the m21's very soon and will have some results up. Be patient my friend. Paul
Old Dec 9, 2003 | 02:11 AM
camp1320.com's Avatar
ROCKET, that was great. Why dont you start your own tunning and engine/trans building sessions. Im sure more then alot of people would be interested.!!!!!!!!
ROCKET
hey any word on the cams.? we got a few backorders over here
Old Dec 9, 2003 | 11:10 AM
Rocket's Avatar
Default Re: EF-1 (camp1320.com)
I maybe solving my cam shortage problem in the coming months. Stay tuned.
Old Dec 15, 2003 | 07:17 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">I maybe solving my cam shortage problem in the coming months. Stay tuned. </TD></TR></TABLE>
for Rocket. Keep us posted.
EJ8 GSR-T
Jul 21, 2006 11:02 PM
DA-9mordef
Apr 27, 2006 10:04 AM
VtecDA9
Oct 14, 2005 02:20 PM
thehatchninja
Jun 10, 2005 11:37 AM
LiveWire401
May 9, 2003 09:32 AM
