4DR FRONT END CONVERSION
Old Jun 12, 2008 | 01:44 PM
allstarr7's Avatar
Default 4DR FRONT END CONVERSION
1995 CIVIC 4DR , IV SEEN IT ON THE INTERNET OF A 4DR WITH A COUPE FRONT END, I LIKE THE COUPE FRONT ENDS WAYY BETTER, SO I WAS JUST WONDERING,
DO I NEED COUPE FENDERS, HOOD AND BUMPER, OR WHAT?
LMK
THANKS!!!
Old Jun 12, 2008 | 08:06 PM
allstarr7's Avatar
wow
noone?
Old Jun 12, 2008 | 08:47 PM
Scott.'s Avatar
Default Re: (allstarr7)
uhm correct me if im wrong but arn't 5th gen coupes and 4dr the same front end?
Old Jun 12, 2008 | 09:17 PM
-JSpecEk*9-'s Avatar
Default Re: (skittle_107)
thats what im thinking
Old Jun 12, 2008 | 09:20 PM
EcivicG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skittle_107 &raquo;</TD></TR><TR><TD CLASS="quote">uhm correct me if im wrong but arn't 5th gen coupes and 4dr the same front end?</TD></TR></TABLE>
not familiar about generations about but i know that the 92-95 coupe and sedan front ends are different.
the hood, fenders and bumper are longer then the coupes.
the sedan has a wide "grill" not sure what to call it and smaller foglights.
the coupe has a smaller grill and the folights are seperated. and imo looks better.
i would think you' need hood fenders, bumper, and possibly radiator core support?
but im not sure on that one.
Old Jun 12, 2008 | 09:21 PM
mattyfo0z's Avatar
They're the same for the most part, but the coupe and hatchback have a different front bumper. Oh, and I know all the parts aren't interchangeable.
@ op: You need headlights, fenders, hood, and bumper. I believe you MIGHT need to weld a new radiator support, but I'm not 100% positive on that one. Let somebody else chime in for a more precise answer.
Old Jun 12, 2008 | 11:27 PM
H22Ej1's Avatar
Shenanigans
Default Re: (.mattyz_)
you def need
coupe/hb fenders
coupe/hb hood
coupe/hb bumper
may need
coupe/hb headlights and corners...not sure if these differ from the 4dr
could get
coupe/hb core support to get everything to fit perfectly
Old Jun 13, 2008 | 09:33 AM
LD-rhdEG6's Avatar
i own a 4door and wanted to do the conversion but it will look like **** unless you pay a body shop to do it the right way. The 4door and 2door share the same headlights,hood, and rad support. The fenders bumper and corners are different. the 2door fenders are a little shorter and CANT bolt them to a 4door I TRIED IT. only way to get the conversion right would be to cut the two door and 4door denders in half weld together and bondo. if you wanted you could just put the coupe bumper but it makes the corner lights stick out the 2door bumper is skinnier than the 4door and you wont be able to run the 5mph crash bar with a coupe bumper installed. If you get a body shop to cut/weld and all the other stuff it could look right heres a pic
Old Jun 13, 2008 | 09:50 AM
doggworld1233's Avatar
you need hood fenders bumper and corners lights from the coupe/hatch. rad support, lights can be used from the 4 door/
Old Jun 13, 2008 | 11:56 AM
fmchonda's Avatar
and how much costs the conversion if i want 2 find fresh non used parts ????
Old Jun 13, 2008 | 12:24 PM
Scott.'s Avatar
Default Re: (fmchonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EcivicG &raquo;</TD></TR><TR><TD CLASS="quote">
but im not sure on that one.</TD></TR></TABLE>
my baddd, i'll stick with my 6th gen knowledge =].
Old Jun 13, 2008 | 05:45 PM
tuned2's Avatar
Default Re: (LD-rhdEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LD-rhdEG6 &raquo;</TD></TR><TR><TD CLASS="quote">i own a 4door and wanted to do the conversion but it will look like **** unless you pay a body shop to do it the right way. The 4door and 2door share the same headlights,hood, and rad support. The fenders bumper and corners are different. the 2door fenders are a little shorter and CANT bolt them to a 4door I TRIED IT. only way to get the conversion right would be to cut the two door and 4door denders in half weld together and bondo. if you wanted you could just put the coupe bumper but it makes the corner lights stick out the 2door bumper is skinnier than the 4door and you wont be able to run the 5mph crash bar with a coupe bumper installed. If you get a body shop to cut/weld and all the other stuff it could look right heres a pic
absolutly correct! I guess no one reads accurate information any more...
To reitterate
Coupe/hatch and Sedan share the same hood, radiator support, and headlight housings. the front bumpers, fenders, and corner lights are different.
YOU CANNOT BOLT A COUPE/HATCH DOGHOUSE ONTO A SEDAN IT WILL NOT WORK!!
Old Jun 14, 2008 | 03:22 AM
H22Ej1's Avatar
Shenanigans
Default Re: (tuned2)
im pretty sure the sedan has a different sized hood than the coupe
the part numbers from honda are the tell, coupe and hatch are the same part number, the sedan has a different part number
Old Jun 14, 2008 | 08:54 AM
Rok_Stok's Avatar
Default Re: (H22Ej1)
You'll get to like the sedan front the way it is, it's tasteful and has plenty of JDM goodies to go with it. Rock stock now or change it back when you regret spending all that money later. EG9 ftw. Someone please show this guy a pic of a clean 4dr.
Trust me dude, 4dr eg's are cool the way they are.
Old Jun 14, 2008 | 10:01 AM
muzammil's Avatar
Default Re: (Rok_Stok)
agree!! Ferios are hot.
Old Jun 14, 2008 | 12:57 PM
mattyfo0z's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rok_Stok &raquo;</TD></TR><TR><TD CLASS="quote">You'll get to like the sedan front the way it is, it's tasteful and has plenty of JDM goodies to go with it. Rock stock now or change it back when you regret spending all that money later. EG9 ftw. Someone please show this guy a pic of a clean 4dr.
Trust me dude, 4dr eg's are cool the way they are.</TD></TR></TABLE>
Yeah, but the foglights look like sh*t compared to a coupe/hatch IMO.
Old Jun 14, 2008 | 07:48 PM
NastyHabitzCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuned2 &raquo;</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure the sedan has a different sized hood than the coupe
4dr hoods are longer, period. and yes Ferios are where its at
Old Jun 15, 2008 | 07:22 AM
T-HEAD EG8's Avatar
this is mine [IMG][/IMG]
Old Jun 15, 2008 | 08:05 AM
marquisdee1018's Avatar
Default Re: (T-HEAD EG8)
At first, I wanted to change my front bumper also. But when I starting seeing sedans with fogs and lips like this one, I decided to keep my sedan bumper.
Old Jun 15, 2008 | 08:39 AM
anthony890's Avatar
sickest eg i have ever seen ^
Old Jun 15, 2008 | 09:14 AM
-JAWSHUA-'s Avatar
they are different. the coupe front does look better imo as well. not sure about the conversion though
Old Jun 15, 2008 | 12:44 PM
austinkli's Avatar
Default Re: (-JAWSHUA-)
imo stick with it stock, ask falkensir, he had a pretty sick *** 4dr, here lets see if i can find a pic. The front ends are so similiar it's almost not worth changing, you're spending a lot of money to do this that you could be using more wisely with it. again, this is all imo, you do what makes you happy with it, but this is what your eg sedan could look like. This one used to belong to FalkenSir.
check out this thread: https://honda-tech.com/zerothread?id=1783886
it's got some pretty sweet sedans in it and may give you some good ideas.
Old Jun 15, 2008 | 03:17 PM
Rok_Stok's Avatar
Default Re: (austinkli)
Gotta love Frost White, it's the best.
This thread has been getting me to Google some Ferios and I have to say I'm finding the front bumper quite baller, especially in Frost White. Did I mention I like that color?
Okay, I'l contribute a little more... here's my favorite 4dr civic b20vtec on a 4lug ITR conv. whooping a K20 ek...they sound badass....guess what color the 4dr is...
http://www.youtube.com/watch?v=jL9L6xocSwg
Modified by Rok_Stok at 9:05 PM 6/15/2008
Old Jun 17, 2008 | 04:55 AM
allstarr7's Avatar
this is mine but i just like the coupe front end, but that what 4 dr with the mugen lip , looks sick
jadugartir
21
Nov 24, 2007 06:18 PM
xci_ed6
Mar 24, 2007 11:46 AM
vietxdragon
Feb 24, 2006 05:05 PM
94HondaDx
11
May 18, 2005 02:37 PM
tmkpres
Jan 9, 2003 10:01 AM
