Bad Tune?
Hey i was just wondering if anyone could help me out. I just got my car tuned and now sometimes it bogs out around 5700RPM.. I dont know much about tuning but im pretty sure its happening because of to much fuel being dumped in around that RPM.
Really i just wanted to have someone recheck my Hondata Bin File see if anything looks off cause it does to me.
I have a Type R Stock Block and Tranny and a Type R Head Milled With Stage2 Cams. Also i got RC370cc Injectors and a Walbro 255lph Fuel Pump, AEM FR & FPR....
Heres a screen shot of my Low Speed Fuel Table:
Download My Hondata Bin:
http://www.2shared.com/file/34....html - HONDATA BIN FILE
Mine sometimes does the same thing, i am tuned on the hondata S100, it does it between 5k-5500rpm a small bog then it just goes,nothing happenes before or after that RPM range....REALLY weird!!
I am at work and unable to download your bin file, but along with a possible rich mixture other factors such as vtec xover point and timing in that area of the map could cause a dead spot..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline32 »</TD></TR><TR><TD CLASS="quote">I am at work and unable to download your bin file, but along with a possible rich mixture other factors such as vtec xover point and timing in that area of the map could cause a dead spot..</TD></TR></TABLE>
I have that same issue , around 3k to 3400 ,.
And 5k to 5600
But im on boost , so its different im sure , same issues , just more amplified for me
With the turbo setup. its complete BS
IMHO
And 5k to 5600
IMHO
I boost my R as well, I to have a small hesitation about 3200 or so...When I tuned it I tried everything to get rid of it...I put in about 3 degrees of timing in that load/rpm range and was able to minimize the issue..I am on stock cams and think its more of a cam profile burp in my case..
after that early burp my car pulls steady up to about 9k..
The map looks like it could use some smoothing possibly re-tuning.
Without a datalog including lamda/airfuel feedback you won't get any kind of accurate feedback on your issue.
