VSS wiring pin out VSS wires
Old Jun 12, 2008 | 07:23 AM
DustinRose's Avatar
Default VSS wiring pin out VSS wires
for any poor soul attempting to research a pin out for the electric VSS plug here it is
i found a couple people saying it was
groud, signal, power
but its not, i have been messing with it a couple days
if you are holding the clip in your hand, with the wires side pointing at you, and the release clip facing up it goes
1. ground (black)
2. power
3. signal
Old Jun 12, 2008 | 09:07 AM
gringo7718's Avatar
Default Re: VSS wiring pin out VSS wires (DustinRose)
I think this is a 92-95 civic vss
Old Jun 12, 2008 | 11:40 AM
xalents23's Avatar
Default Re: VSS wiring pin out VSS wires (gringo7718)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringo7718 &raquo;</TD></TR><TR><TD CLASS="quote">I think this is a 92-95 civic vss
Size:  78.5 KB</TD></TR></TABLE>
That is how my 1992-1995 VSS speed sensor wires are.
Old Sep 7, 2012 | 12:53 PM
Mishako129's Avatar
Does anybody know how i can fix the wiring harness adapter that goes to the VSS? One of the pins is partially broken off.
Old Sep 7, 2012 | 12:58 PM
Mishako129's Avatar
Will this work? Its for a OBD1 Acura and the adapter looks the same.
http://www.ebay.com/itm/VSS-SPEED-SE...#ht_500wt_1289
Old Sep 7, 2012 | 02:44 PM
crx_si-r's Avatar
I can sell you the terminals an boots if you new them so you don't have to solder just crimp and go
Colby71
Jan 29, 2008 06:05 PM
Ep1dem1c
Jul 3, 2007 10:51 AM
J-g-D-s-M-r
Sep 12, 2006 11:52 AM
joker_333
Feb 19, 2006 11:29 AM
mike93eh
18
Aug 14, 2005 01:56 PM
