89 crx si "stuttering" at low rpms
Old Jun 11, 2008 | 08:29 PM
Booz's Avatar
Default 89 crx si "stuttering" at low rpms
First, and I don't know if this is related, but if I cut my car off for just a minute or so and try to start it up it will start up then bog down until it dies. Each time I tried to start it up directly after it cuts off sooner and sooner. I have to let it cool off I guess at which time it starts up fine without bogging down until it cuts off.
My problem though, is that a lot of time my car will "stutter" (not sure how else to say it) when I start off or when I'm at low rpms even in a higher gear. I've noticed that in cooler weather it doesn't do it, but in NC summers are inthe 90s and it does it quite often. I've gotten to the point where I have to rev up to about 4k rpms so that it won't stutter. It seems to last only until about 2k rpms and then it's fine, unless I go below that.
Old Jun 11, 2008 | 09:13 PM
whitterjohn's Avatar
Default Re: 89 crx si "stuttering" at low rpms (Booz)
i have a a few problems like that also with my 91 crx one thing i found out is when i would take my intake off it wouldnt do it anymore but i just dont know why it does it
Old Jun 12, 2008 | 01:29 AM
~sp33~'s Avatar
EFB055
Default FV-QR
Your first problem sounds like a main relay or fuel pump problem.
Old Jun 20, 2008 | 01:30 PM
Booz's Avatar
Default Re: FV-QR (~sp33~)
I think it may be the main relay. Had a problem with my car not starting up the other day, just like I did on my 90 crx before I changed the main relay.
Old Jun 20, 2008 | 02:14 PM
zcmotor's Avatar
i also had the same problem on low rpms and high rpms but it just went away i dont know what it was...
Old Jun 20, 2008 | 09:51 PM
1990CRX_Si's Avatar
Default Re: (zcmotor)
I have the exact same problem. The car starts fine in the morning, but if I shut it off and try to restart, it fires momentarily and dies. Then takes a few minutes of waiting before it will fire up and stay running.
I also have the same "stuttering" when it's hot outside problem. I think they are related. When it's hot out and I'm cruising the car has a distinct and consistant misfire. Every 3 seconds or so you can feel it misfire.
Neither of these problems occur during the winter or when it's not hot outside.
I'm checking my relay tonight for cracked solder joints and may replace/repair tomorrow.
Modified by 1990CRX_Si at 11:17 PM 6/20/2008
Old Jun 20, 2008 | 11:34 PM
zcmotor's Avatar
Default Re: (1990CRX_Si)
well i have replaced the main relay and the resistor box and it hasnt done it. maybe the main relay was the problem i guess
Old Jun 22, 2008 | 05:40 PM
1990CRX_Si's Avatar
It's the main relay. Mine had "dry" solder joints and so I re-soldered. The car actually runs better. No more misfire and have not had the "no hot start" problem (so far). The re-solder was amazingly easy.
Check this website: http://techauto.tripod.com/mainrelay.htm There is a huge amount of info about the main relay. I have however noticed the site goes down due to overtrafficing, so be patient.
EDIT: Here is a similar site http://www.marklamond.co.uk/te...y.htm
Modified by 1990CRX_Si at 8:15 PM 6/22/2008
Old Jun 24, 2008 | 04:24 AM
Booz's Avatar
Did the solder fix the 'stuttering' while driving a low rpms?
Old Jun 24, 2008 | 06:22 AM
acmoc's Avatar
Default Re: (Booz)
mine has hard stats on the first try, for me it was the fuel pump
Old Jun 27, 2008 | 07:18 AM
chuckmn87's Avatar
Default Re: (acmoc)
so the main relay was the cause?
i just had this problem arise with my 90 crx si, stuttering at low rpms, higher rpms its fine
Old Jun 27, 2008 | 08:47 AM
bonestock92si's Avatar
nevermind i did a seach
Modified by bonestock92si at 12:01 PM 6/27/2008
Old Jun 27, 2008 | 10:05 AM
Spikey640's Avatar
sounds like main relay those are the same symptoms that my friends DA had
Old Jun 28, 2008 | 11:45 AM
chuckmn87's Avatar
Default Re: (Spikey640)
i just took my relay off to check, and it had the dry solder joints, so i took the solder off and re-soldered, runs like a champ now
Old Jun 30, 2008 | 10:14 AM
acmoc's Avatar
Default Re: (chuckmn87)
anyone have a link on how to soder the connections, I wanna do this to my relay. You just use regular flux right?
Old Jul 2, 2008 | 07:00 AM
chuckmn87's Avatar
Default Re:
Okay, well i dont think the relay fixed my problem, yesterday it got pretty hot outside, and my car started acting up agian. the stutter while slightly on the gas and it once didnt want to start took a little push on the gas and holding for it to maintian rpm or it would hesitate then die.
anyone have any other ideas.... only does this when its hot
Old Jul 2, 2008 | 07:17 AM
D50boy's Avatar
Default Re: Re: (chuckmn87)
Excellent link. I think I'll try this out on my moms Vigor. It'll sometimes have trouble starting after being parked in the sun.
Old Jul 3, 2008 | 07:53 AM
amg2y's Avatar
So I resolder all the connection on the back of the relay. Now my oil light did not turn on when I start it up. Do you think I disconnect the wire somewhere? Please help. Thanks,
Booz
Mar 26, 2012 09:37 PM
lukehonda
Aug 4, 2011 03:36 PM
premo_si
11
May 21, 2008 05:12 PM
XspeedSi02
Mar 3, 2008 09:51 PM
DubbleD
Sep 22, 2003 05:28 PM
