What size slick will fit??? DEL SOL
Almost finished with my all motor del sol and looking for some slicks. Seen alot of good deals for wheels and tires but not sure what will fit! "203" has a great set for sale and there 26x10.5..... WILL THESE FIT? Or any advice???
Please help!!!
Please help!!!
Those 26" slicks not only will not fit your stock wheel wells...Also, unless you're making over 350whp all motor they will slow your car down. 24.5x8.5x13 // 23x8x13 // 22x8x13 // 24.5x8.5x15 // 23x8.5x15 are your options. Depending on power levels and the final gearing you want to achieve depends on what tire you should go with.
https://www.mandhtires.com/
-Froth
-Froth
Thanks for the info. Needin to find a set that the track will let me use. (Cheater Slicks only) I know that alot of people cut on there fenders and trim some plastic panels. Is this possible?
And yes i am running close to 330 hp to 345 hp after a small shot on top of the NA. I would like to try both a 26 and smaller tire to see what will happen if at all possible the 26 fits.
93first1
May 5, 2006 09:07 AM
