98 prelude injector issues
Old Jun 11, 2008 | 05:23 PM
spooled-r's Avatar
Default 98 prelude injector issues
i bought a 98 honda prelude 5spd that was not running but if you spray starter fluid in it it starts rite up. first though was a fuel pump, but it is good and gets pleanty of pressure. i loostened the bolt on the fuel rail and its getting good preasure to the rail, and w injectors still in tact when you turn the key on in the car no gas comes out the injectors but when disconecting rail the lil bit that falls from the injectors into the motor starts it so i am pretty sure the injectors are not squirting and that the problem, i have tried 3 ecu's a new main relay, checked the oil pessure regulator and crank position sensor just trying to cover all things i could think of. but no luck was wondering if any one had any sugestions or has ran accross a similar problem
Old Jun 13, 2008 | 07:40 AM
spooled-r's Avatar
Default Re: 98 prelude injector issues (spooled-r)
bump
Old Jun 14, 2008 | 01:42 PM
RHD_BB4T's Avatar
sounds like a distributor problem
Old Jun 16, 2008 | 06:17 PM
spooled-r's Avatar
Default Re: (RHD_BB4T)
all ready tested distributor and its working fine
93accordmike
K Series
Mar 21, 2012 09:20 PM
sg
Jan 15, 2008 11:39 AM
Jmunk
Feb 17, 2006 10:09 AM
lazykiwi
Dec 23, 2004 11:50 PM
PyroVTEC
Dec 9, 2001 10:35 PM
