Reversing polarity for thin metal?
Old Jun 11, 2008 | 04:06 PM
f22beast's Avatar
Default Reversing polarity for thin metal?
I've been welding for like six months here and there on my EG and my senior engineering project, so im no expert. A guy a work told me today that if you reverse the polarity on a GMAW Mig welder you can actually push the wire into the joint and make a tiny weld bead, I haven't tried it, sounds like BS has anyone heard of this.
Thanks
Old Jun 11, 2008 | 11:14 PM
KENetics1's Avatar
Default Re: Reversing polarity for thin metal? (f22beast)
what polarity is your gun and work clamp connected to now?
Old Jun 12, 2008 | 02:30 AM
onefstek's Avatar
I know that you reverse polarity if your using gas less wire. But in not sure how it works on regual gas mig.
Old Jun 15, 2008 | 03:36 PM
9295EJ-t's Avatar
doesnt make since... thats like saying if you reverse the polarity on a TIG machine it will allow for smaller material...
it just doesnt work...
maybe it will make a small bead, but there is gonna be a lack of penetration..
to weld thin ****, you just turn the voltage and wire speed down..
they use MIGs all the time on auto body repairs.. and thats sheet metal... doesnt get a lot thinner than that...
Old Jun 15, 2008 | 06:58 PM
narfdanarf's Avatar
Default Re: (9295EJ-t)
You can reverse the polarity with any welder you are using. Look in the manual your welder came with it should tell you max amperages with the polarity reversed for how ever big your electrode/wire is.
I can't really see the benefits, but the option is there if you feel the need to do it.
Old Jun 15, 2008 | 08:46 PM
Bjorn's Avatar
I've never heard of it doing that, but since it only takes ~5min. to do it, why not try it?
Old Jun 16, 2008 | 08:45 AM
9295EJ-t's Avatar
Default Re: (narfdanarf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narfdanarf &raquo;</TD></TR><TR><TD CLASS="quote">I can't really see the benefits, but the option is there if you feel the need to do it.</TD></TR></TABLE>
exactly... so what are the benefits.... there are none...
Old Jun 19, 2008 | 10:02 PM
wantboost's Avatar
Who is Mr Robot?
i could see the benefit on thin metal as it would reduce burn through
but in theory it would reduce penetration on thicker metals
Old Jun 23, 2008 | 01:04 PM
Desir Performance's Avatar
Default Re: (wantboost)
I know that works for stick welding DCEN or DCEP.
Old Jun 23, 2008 | 09:23 PM
ssmdc2's Avatar
I know there are certain benifits when doing this with the TIG. I forget which way is which but one way keeps more heat in the metal and less in the torch and the other way is exact opposite, less heat in the metal and more in the torch. There must be similar principles when using MIG I know I read it in Millers handbook. They have ALOT of good info on their site.
PolishSasquatch
Welding / Fabrication
14
Apr 12, 2008 10:35 AM
rdssk8rcs1
Paint and Body
Sep 21, 2007 06:27 AM
dopefeen
10
Oct 19, 2006 09:49 AM
mrbsponge
12
Mar 26, 2005 06:02 AM
cdog19
Feb 3, 2004 10:39 AM
