is this welder ok?
Old Oct 17, 2006 | 04:42 PM
dopefeen's Avatar
Default is this welder ok?
would this welder be ok for doing body work and exhaust work? i think the 70Amps is to low or is it ok? and one bad thing i suppose is the heat setting -theres only 4. but for the time being until i invest in a good welder would this work?
Mig Wire Feed Welder : 70 A wire-feed welder
Infinite wire speed control
High-efficiency transformer; heat selection dial with four settings
Includes wire-feed welder, gas regulator, gas hose, two hose clamps, welding shield, one spool of flux-core wire, hammer/brush, quick-start guide and instruction manual
Uses MIG (gas) or flux-core (gasless) wires
Old Oct 17, 2006 | 05:53 PM
dopefeen's Avatar
Default Re: is this welder ok? (dopefeen)
wow no one?
Old Oct 17, 2006 | 06:25 PM
F20Cteg's Avatar
You have to ask yourself, what are your plans? What ga material are you looking to weld?
Old Oct 17, 2006 | 08:30 PM
dopefeen's Avatar
Default Re: is this welder ok? (F20Cteg)
i did say in my post. like body work (panels and stuff) and also probably try doing custom exhaust work...or headers and stuff.
Old Oct 18, 2006 | 02:48 AM
Shepherd's Avatar
I have a 100amp MIG and it's good for everything automotive related. I've never had a job it couldn't accomplish at 100amps.
Honestly though, 4 settings is very limited. I have 10 and I use all of them. How adjustable is the speed of the wire feed?
Old Oct 18, 2006 | 05:41 AM
dopefeen's Avatar
Default Re: is this welder ok? (Shepherd)
Infinite wire speed, but heat is 4 settings. - im just really picking this up to finish up my car cuz i've just paid for school and all and later im plannin on picking up a good welder...but like 70amps would be enuff to do both body panel patching and welding tubing?
Old Oct 18, 2006 | 09:56 AM
mopar junkie's Avatar
Every 0.001" of material thickness needs roughly 1 amp of power. Do the math.
Old Oct 18, 2006 | 01:51 PM
dopefeen's Avatar
Default Re: (mopar junkie)
thanks.
Modified by dopefeen at 9:51 PM 10/18/2006
Old Oct 18, 2006 | 03:05 PM
ManBearPig4silly's Avatar
Default Re: (dopefeen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dopefeen &raquo;</TD></TR><TR><TD CLASS="quote">thanks. but a simple yes and no could've also done it too. </TD></TR></TABLE>
Yeah but then would you know what to look for in a welder?
Old Oct 18, 2006 | 07:14 PM
dopefeen's Avatar
Default Re: (ManBearPig4silly)
im just joking bro.. lol no really thanks for the answer he's probably the only one that helped out. - but umm like exhaust pipes and such wat gage are they?
Old Oct 19, 2006 | 09:49 AM
F20Cteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mopar junkie &raquo;</TD></TR><TR><TD CLASS="quote">Every 0.001" of material thickness needs roughly 1 amp of power. Do the math.</TD></TR></TABLE>
Most people would burn through with those settings. Try more like half. IF you are a little more adept, then you could step it up and move faster.
&gt;&gt;&gt;&lt;&lt;&lt;
kornerk12
Welding / Fabrication
11
Oct 26, 2008 11:03 PM
oramac_eg
Oct 17, 2008 08:10 AM
f22beast
Jun 23, 2008 09:23 PM
PolishSasquatch
14
Apr 12, 2008 10:35 AM
Touge Tuning
15
Feb 15, 2006 11:19 AM
