Flexcore?
Old Sep 20, 2007 | 05:03 PM
rdssk8rcs1's Avatar
Default Flexcore?
Not sure if thats how you spell it but is this type of welding/welder bad to use with body work?
Ive heard mixed opinions on this so i was hopoing to get a more educated one from someone.
Thank you in advance
Old Sep 20, 2007 | 05:18 PM
Pockets's Avatar
fluxcore. it's a wire that supplies it's own shielding gas (no tank needed). you can use it, but your welds will not look as clean. there will be lots of splatter and lots of smoke.
Old Sep 20, 2007 | 06:13 PM
Top Ramen's Avatar
Default Re: Flexcore? (rdssk8rcs1)
fluxcore will work, but is far from ideal.
best of luck with your project.
Old Sep 20, 2007 | 07:52 PM
rdssk8rcs1's Avatar
Default Re: Flexcore? (Top Ramen)
i heard something about it causing the metal to rust or something after its all done?
Does that not sound right?
Old Sep 20, 2007 | 08:14 PM
shad0wslay3r's Avatar
it will rust either way if you leave it as bear metal
Old Sep 21, 2007 | 06:27 AM
rdssk8rcs1's Avatar
Default Re: (shad0wslay3r)
alright. Thanks. So as long as i treat it just like a normal weld and primer it soon after teh work is done it will be fine?
f22beast
Welding / Fabrication
Jun 23, 2008 09:23 PM
torontoefsedan
Feb 2, 2008 05:50 AM
spoonhatchblack
Jan 19, 2005 10:31 AM
GroundZer0 336
Nov 11, 2003 07:16 PM
fe519
Jul 9, 2003 01:24 AM
