Should I Attempt to Get Warrenty Repair on Bad Synchro?
Old Jul 17, 2002 | 07:53 AM
onyx00's Avatar
Default Should I Attempt to Get Warrenty Repair on Bad Synchro?
On the 2 - 3 shift I get grinding above 7000 RPM. It's consistent, and occurs everytime (unless I feather the clutch on the shift). No problems on any other gears/synchros.
So should I wait for it to get worse to ask for warrenty work or should I attempt now? I am at 18K miles, ~15 months old car.
Old Jul 17, 2002 | 07:54 AM
Rob :190:'s Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (onyx00)
yes, the worst they can say is no, althought when i take mine in for a similar problem, they damn well better say yes
Old Jul 17, 2002 | 08:12 AM
TeamRedlineITR's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? ( Rob)
very common problem, they should do it under warrenty... next thing will be 5th gear grinding... if it takes that long to get it fixed... thats what my tranny is doing.. should get it fixed within the next week..
Old Jul 17, 2002 | 08:25 AM
SamC's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (TeamRedlineITR)
I've been hearing people with bad synchro...how can you tell if you have bad synchro? what caused it to go bad? is it a manufacture defects?
Old Jul 17, 2002 | 08:58 AM
Tommy_Gunns's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (SamC)
High RPM grinding is a symtom of bad synchro's. My ITR has this problem as well. At low RPm everything works fine but up high (7000 rpm and above), it grinds.
Old Jul 17, 2002 | 09:03 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
They'll just tell you it was never meant to be revved that high so it must be your fault.
Acura warrany covers nothing on a Type R. It's fast so therefore you must abuse it.
Old Jul 17, 2002 | 10:00 AM
norice's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (newt2)
Had my tranny apart last week. After 19k hard miles (car is not a daily driver), synchros looked like new - no worn edges.
Your dealer may cover the syncros under warranty, but they shouldn't.
Worn synchros on a Type-R are caused by poor shifting technique.
Old Jul 19, 2002 | 07:44 PM
onyx00's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (norice)
Um, I don't know if I agree with that but it's your opinion.
Old Jul 19, 2002 | 07:45 PM
Reid's Avatar
Global Moderator
Sorry, but it's true.
Same thing goes for all b series trannies.
EDIT: I'm talking about syncros going bad early.
[Modified by Reid, 6:45 PM 7/19/2002]
Old Jul 19, 2002 | 08:07 PM
ITR21's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (Reid)
my 5th grinds its sad
Old Jul 19, 2002 | 10:51 PM
mafay2's Avatar
New User
Just go try it out, it won't hurt!!
Old Jul 20, 2002 | 12:34 AM
IN2VTEC's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (mafay2)
Damn..my 3rd gear synchro is out, too on my R tranny...when i shift above 5,000rpm it grinds like a ****...and when racing.i gotta force the shifter into 3rd with a loud crunch!
Question is....how much will it cost to get fixed??? I mean the labor..that's what I'm worried about...my stuff's not covered under warranty....so can you tell me how much it will cost to get the synchro fixed as far as LABOR GOES....thanks.
Old Jul 20, 2002 | 12:40 AM
type r 01-1063's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (IN2VTEC)
to save on labor, i recommend dropping the tranny yourself and take the tranny to get the synchro's replaced
Old Jul 20, 2002 | 02:11 AM
IN2VTEC's Avatar
Default Re: Should I Attempt to Get Warrenty Repair on Bad Synchro? (type r 01-1063)
Hey thanks man..sounds like a good idea...So then..how much would I be expecting to pay on labor then...for the synchros to be replaced...how much would I save by dropping the tranny myself? Thanks...
thundernoodle
Transmission & Drivetrain
Aug 1, 2010 06:20 PM
d-yup
Apr 9, 2009 11:55 AM
New Dimensions
24
May 4, 2005 10:29 AM
Grandprix
Feb 25, 2003 02:51 PM
2qwik2nv
Apr 11, 2002 02:56 PM
