Any suggestions???? Transmission problem.
Old Jun 11, 2008 | 08:23 AM
hatchbkdrvr's Avatar
Default Any suggestions???? Transmission problem.
A couple of days ago i thought my starter was bad so i pulled it out to get it tested.
But it tested good, so i put it back on. The problem turnd out to be some corrosion on the positive terminal cable ground.
Anyways sense then my transmission has been [freak]ed up.
My car seems to skip all the gears and go straight to 4th.
Any suggestions?
Could this be a bad sensor or something?
I checked my CEL and it gave me: 70 = A/T Transaxle.
Oh yeah ive got a 98 civic sedan with an automatic transmission.
Old Jun 12, 2008 | 07:23 AM
ttt
Old Jun 12, 2008 | 08:20 AM
vtecb18c's Avatar
Default Re: (hatchbkdrvr)
you might have unplugged the wire going to the trans..im not sure what its called but its right by the starter...thats the only thing i can think of
Old Jun 12, 2008 | 08:42 AM
fastrc2's Avatar
Default Re: (vtecb18c)
ok if its stuck in fourth that is the tranny's limp-home mode. dont drive it around this way, more than you need to, its very bad for it. the code number 70 is not a dtc number, the honda pgm tester numbers only go up to 41 for a/t codes. it should be like a p0720 is an example for countershaft speed sensor. of course this is all void if you have a civic hx, they have a cvt tranny and those are special they go up to 43 in the honda numbers. try using a more common higher line tester, i have seen the chepos at autozone all the time spit our a completely wrong information.
Old Jun 12, 2008 | 11:59 AM
Default Re: (fastrc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrc2 &raquo;</TD></TR><TR><TD CLASS="quote">ok if its stuck in fourth that is the tranny's limp-home mode. dont drive it around this way, more than you need to, its very bad for it. the code number 70 is not a dtc number, the honda pgm tester numbers only go up to 41 for a/t codes. it should be like a p0720 is an example for countershaft speed sensor. of course this is all void if you have a civic hx, they have a cvt tranny and those are special they go up to 43 in the honda numbers. try using a more common higher line tester, i have seen the chepos at autozone all the time spit our a completely wrong information.</TD></TR></TABLE>
I tested it by using a wiring and watching the cel blink. It blinked 7x (1 sec each time) =code 70
So how do i get it out of limp mode?
Old Jun 12, 2008 | 01:01 PM
fastrc2's Avatar
o the code you read was form the engine computer not the tranny computer. so heres the deal. you need to scan the transmission computer
so if there is a code in the tranny, which is what the engine computer is pushing you to check, you may have noticed the D4 light was illuminated lately. this is the light for diagnosis. unless you can get a scan tool that can also read powertrain computers, but this costs a lot more than just a scanner that can do engies. to check the tranny, there is a service connector to jump in the right front footwell on the right side wall. jump the 2 pins. this connector should only have 2 wires in it. then turn the key on. observe the d4 light the short blink is the first digit to the code, a long blink equals ten short blinks, what ever it spits out will be added together. please not the code you think you have, and the types of blinks you observed. this will give you and then me a code to help you with. the limp mode will go away once the code is erased after the problem is fixed.
08siRob
Honda Civic (2006 - 2015)
Nov 15, 2022 03:57 PM
Mzmonika
Sep 5, 2016 07:58 AM
Cuda
Dec 4, 2006 11:11 PM
SoOHiGH
Apr 1, 2005 09:58 PM
