Brake Pads: Are inside different from outside pads? HELP PLEASE :)
Old Jun 10, 2008 | 08:59 PM
ericlee303's Avatar
Default Brake Pads: Are inside different from outside pads? HELP PLEASE :)
Here's the story folks, I bought these AP Racing pads from HK when I was there.
I put one side in, no problems. The other side, it seems the inside pad is too thick, and is causing the disc to interfere with the caliper.
Are inside different from outside? They look the same to me, and are not marked.
If they are, I need to switch them. Problem is, I can't seem to get the inside pad out of the bracket.
HELP!
Old Jun 10, 2008 | 09:05 PM
ITR.#1446's Avatar
Default Re: Brake Pads: Are inside different from outside pads? HELP PLEASE :) (ericlee303)
did you push the piston all the way back in the caliper?
Old Jun 10, 2008 | 09:49 PM
BlueIntegraBoy's Avatar
Inside pad has the metal tab.
Old Jun 10, 2008 | 11:34 PM
db8sirg's Avatar
Default Re: Brake Pads: Are inside different from outside pads? HELP PLEASE :) (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Inside pad has the metal tab.</TD></TR></TABLE>
well oe for sure, but aftermarket not always.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericlee303 &raquo;</TD></TR><TR><TD CLASS="quote">
Are inside different from outside? ..</TD></TR></TABLE>
no they should be the same thickness.
Old Jun 12, 2008 | 04:32 AM
ericlee303's Avatar
Thanks for the responses guys, I finally got them to fit. The cylinder was a bit stuck, and I had to fight with it to get that extra bit of play. Calipers must be getting old.
BTW inside and outsider ARE the same.
My thoughts on the AP Racing pads on white-box rotors: I think you really have to heat them up before they become really effective. For normal street driving, they actually seem a little less grippy than OEM.
bad-monkey
Honda Motorcycles
Jan 5, 2007 10:37 PM
Tyson
Honda S2000
Nov 30, 2006 07:00 PM
Archidictus
Suspension & Brakes
54
Aug 12, 2005 09:54 PM
FastNFurious
Mar 6, 2004 06:08 AM
misterxhybrid
Nov 7, 2003 08:31 AM
