ON Cold start-up, my idle is stays too low and wants to die, it use to be at 2000rpm until it warmed
Old Jun 10, 2008 | 01:11 PM
Maxcapacity's Avatar
Default ON Cold start-up, my idle is stays too low and wants to die, it use to be at 2000rpm until it warmed
The past couple days I noticed that when I start my car when it's cold the idle wants to stay at between 500-750rpm. before it would go up to 2000rpm until it warmed up then go idle back to normal- 5-750rpm. I am having to hold the gas pedal to warm it up or else the low idle will cause it to stumble and want to die.
Its a B16a head, intake mani., gsr block.
Is there some sort of valve that lets air in past the throttle body to bring the idle higher during warm up?
Is it stuck open or closed?
How can I fix this?
thanks if anyone can help.
Old Jun 10, 2008 | 06:11 PM
hondacivic90zc's Avatar
Default Re: ON Cold start-up, my idle is stays too low and wants to die, it use to be at 2000rpm until it wa
yes there is a valve right on the back of the manifold by the throttle body. It has two 10 mm bolts holding it on and two coolant lines running to the bottom of it. Its called the IACV (Idle Air Control Valve). It looks like a sideways cylinder sort of maybe about 3-4 inches long. Take it off and there is a screen that sometimes gets clogged. Give it a good cleaning and go from there.
Iloveyourhonda92
Apr 11, 2015 07:46 PM
Shadowcat
Sep 14, 2012 07:12 AM
joelmatt89
15
Nov 4, 2009 05:27 PM
nekoabandoned
11
Jul 2, 2008 11:59 AM
b16acrxer
Aug 31, 2004 09:02 AM
