Best advice for a B20Z ?
Old Jun 10, 2008 | 11:48 AM
KeithDigital's Avatar
Default Best advice for a B20Z ?
What's the best setup in terms of Cost, Ease to Install, Performance?
I think I have 3 options -
1. Vtec head on B20
2. 403 Cams, Springs, Retainers, etc for B20Z
3. JRSC B20Z
Thanks.
I currently have H/I/E, just want the next step.
Old Jun 10, 2008 | 11:55 AM
Top Ramen's Avatar
Default Re: Best advice for a B20Z ? (KeithDigital)
What are your budget, hp goals and long-term plans for the motor? Help us to help you.
Old Jun 10, 2008 | 12:29 PM
SolAssassin's Avatar
My personal opinion:
1. JRSC (if you got the $$$)
2. VTEC head (what I did)
3. VT build (unless you're boosting or spraying I wouldn't even bother. you have to buy the parts and them have them installed, and for what?)
Old Jun 10, 2008 | 04:02 PM
Default Re: Best advice for a B20Z ? (Top Ramen)
just looking for the best bang for the buck.
Old Jun 10, 2008 | 06:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithDigital &raquo;</TD></TR><TR><TD CLASS="quote">just looking for the best bang for the buck. </TD></TR></TABLE>
Then I'd go B20/VTEC
https://honda-tech.com/zerothread?id=1676914
https://honda-tech.com/zerothread?id=1555476
Old Jun 11, 2008 | 09:10 AM
ivan93egreppin210's Avatar
i would say b20vtec. if you dont have a vtec tranny then thats the first and most important thing you need. if you plan on leaving the stock pistons, you will have very little piston to valve clearence.clay your motor!!!!! if you want big power, the get hi comp. pistons like RS MACHINE 84 mm itr pistons and a nice lumpy cams. look into "block posting" as a cost effective upgrade. it keeps your sleeves in place. also if you stay stock rods and pistons, i recomend you at least change the rod bolts. from what ive read, it seems like they tend to stretch at high rpm causing spun rod bearings and more. also you need a good breather kit or your setup will not last. all this is nothing without a good tune.
crzymine03
11
Mar 11, 2017 10:36 AM
feriotypeR
Jul 23, 2008 10:45 AM
xtegb16x
Apr 29, 2006 11:06 AM
boostedek9
Mar 4, 2006 03:56 AM
jodesi9
Sep 18, 2002 11:44 AM
