Another wheel stud option..........1996-1998 Acura TL 3.2 rear wheel studs
Old Jun 10, 2008 | 10:29 AM
Toy Civic's Avatar
Default Another wheel stud option..........1996-1998 Acura TL 3.2 rear wheel studs
Just in case people are not aware....................
If you need or want to replace wheel studs, most people are only aware of 3 options:
1) OEM part numbers and OEM length
2) ARP OEM length. The threads are actually OEM length, but the bare part on the ends makes them about 0.2 inches longer than OEM.
3) ARP, Skunk, Blox extended wheel studs. These are always a full inch longer than normal. You must run open ended lugnuts with these.
There is a fourth option out there. It is the OEM rear wheel studs from the 1996-1998 Acura 3.2 TL Sedan. These have the exact same specs as Civic and Integra OEM studs, except that they are 1/2 inch longer. The Honda part number is 90113-SD2-005. You can also go to NAPA, give them the OEM part number, and they will cross reference it to get you the right ones.
Why go with these? So you can have extended studs and still be able to use closed ended lug nuts without bottoming out.
Have a nice day
Old Jun 10, 2008 | 11:02 AM
Luserkid's Avatar
Default Re: Another wheel stud option..........1996-1998 Acura TL 3.2 rear wheel studs (Toy Civic)
But you cant use the front studs? Are they different or something?
Old Jun 10, 2008 | 11:45 AM
Toy Civic's Avatar
Default Re: Another wheel stud option..........1996-1998 Acura TL 3.2 rear wheel studs (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">But you cant use the front studs? Are they different or something? </TD></TR></TABLE>
You can also use the front studs from the 3.2 TL, but they are only 1/4 inch longer than OEM Civic / Integra studs.
That means that the rear studs are longer than the front on an OEM 3.2 TL.
Old Jun 15, 2008 | 10:11 AM
hoo my gosh's Avatar
good info
whats the part # for the fronts?
also, its on backorder from acura. how good are the napa versions?
Old Jun 15, 2008 | 12:09 PM
BlueIntegraBoy's Avatar
Ahh, I remember someone posting a question about longer OEM studs, but I couldn't remember which model it was from. I told him either TL or RL. I also remembering someone posting a pic comparing a stock Integra/Civic to the longer OEM stud, but couldn't find it.
Front TL Studs: 90113-SD4-902 BOLT, WHEEL (SAGA)
Rear TL Studs: 90113-SD2-005 BOLT, WHEEL
Old Jun 16, 2008 | 06:48 AM
Default Re: Another wheel stud option..........1996-1998 Acura TL 3.2 rear wheel studs (BlueIntegraBoy)
any other studs out there that are about 3/4's of an inch longer?
Old Jun 16, 2008 | 10:02 PM
Toy Civic's Avatar
***UPDATES***UPDATES***UPDATES***
The dealer has the Acura 3.2 TL wheel studs on back order for whatever reason.
I went to NAPA and bought wheel studs there instead. I gave them the Acura factory part # 90113-SD2-005 and they indeed cross referenced it with the studs they carry. The NAPA part number is 641-2791. The price is $3.55 each.
I took a pictures comparing the OEM Civic/Integra wheel studs (1.625") versus the OEM TL 3.2 wheel studs (2.0") for a difference is 0.375 inches. Everything else is the same otherwise.
Regarding the front studs from the Acura 3.2 TL, I did not reasearch those as much, but I understand that they are about 0.25 inches shorter than the 3.2 TL rears. So those may be another option.
So again, this serves as another alternative to expensive extended studs from ARP, Blox, or Skunk. You can still have the cleaner looking closed ended tuner lugs and still have the extra meat with more threads for durability.
Old Jun 16, 2008 | 11:05 PM
bmoua's Avatar
good info
Old Mar 27, 2009 | 01:55 PM
vy3tnamezz's Avatar
ok i went to checkers, autozone, advance, acura, and napa. i forgot to write down the part number you posted so i just asked them for the 96-98 Acura Tl 3.2 rear wheel studs every store i went to said the the fronts are longer. they said the rear was 32mm long and the fronts were 42mm long. i couldnt find the one that is 48mm long. so when i finally got home i called all the store and asked them to cross reference the honda part number. Napa was the only store who carry these i guess. checkers said they would have to order them. autozone and advance didnt even no this part # exist. so is that honda part number you posted for sure for the acura tl?????
Old Mar 27, 2009 | 10:04 PM
Toy Civic's Avatar
The correct factory part number is 90113-SD2-005 for the '96-'98 Acura TL. Please use it when you are at the Acura or Napa parts counter. I cannot vouch for Autozone or Checker.
Follow that part number and you will have studs that are 3/8 inch longer.
Old Mar 30, 2009 | 09:25 PM
vy3tnamezz's Avatar
yes for sure when i use both part number at napa works for sure. i wouldn even try checkers, advance or autozone, for those who plan on doing this. i found out the hard way. stick with the part number and go to honda or napa.
Old Mar 30, 2009 | 09:48 PM
raidacaipo's Avatar
well this is all about preference but do alot of people like the closed lug nut look? I personally like the open ended extended look.. it looks racy in my opinion.
Old Mar 31, 2009 | 06:32 AM
vy3tnamezz's Avatar
weill i dont think its all for looks. my stock studs was too short to mount on my aftermarket rims. so instead of buying extended wheel stud which cost 55 dollars and a set of open end lugs which cost atleast 30 dollars, ill just buy a set of acura tl which only cost me 20 dollars here in colorado. .
Old Jun 19, 2009 | 07:23 AM
No_Fear's Avatar
where can i get those studs ? do you have an online shop (which ships worldwide) ?
Old Jun 19, 2009 | 07:54 AM
scrambled_EG's Avatar
I think he said napa or acura dealer..
Btw..nice info Toycivic..good to know
Old Jun 19, 2009 | 07:55 AM
No_Fear's Avatar
yes but i need an online shop i am not from US
*edit*
http://www.oemacuraparts.com for oem parts
Rzoops
Jun 8, 2014 02:07 PM
Radim
Feb 4, 2009 07:57 AM
Toy Civic
Jun 17, 2008 06:14 AM
Toy Civic
Jun 17, 2008 01:52 AM
