Why won't his VTEC work?
Old Jul 17, 2002 | 03:46 AM
eTec's Avatar
Default Why won't his VTEC work?
My buddy has a problem with his VTEC. He has a b16 swap in his 97 civic 4 door. He just had the tranny replaced cause he broke the casing on a pothole. Anyways after the new tranny was put in his vtec won't hit and its causing him to redline at 6500. He also has a CEL but Honda can't find what the prob is cause he has a GSR ecu.
What could be the problem?
Old Jul 17, 2002 | 04:11 AM
g_man80's Avatar
Default Re: Why won't his VTEC work? (eTec)
I'd check the new wires that were run for the vtec. Maybe one of them pulled off when he hit the pothole or when they were fixing it. Also, make sure the oil level is ok. If it's too low I believe the vtec won't engage. Those are the only two things I can think of right now. Good luck.
Old Jul 17, 2002 | 05:10 AM
EKB18BPR3's Avatar
Default Re: Why won't his VTEC work? (g_man80)
i agree with g_man
Old Jul 17, 2002 | 06:06 AM
eTec's Avatar
What wires are you talking about? And his oil level is ok.
Old Jul 17, 2002 | 06:10 AM
98DC2's Avatar
you need to recheck oil/tranny fluid. my friend had this same problem after he replaced his axle. once the tranny has be drained & refilled, it takes a lot more fliud or longer to cycle back through...hope this helps
sleekcivic2004
Jul 30, 2009 06:19 AM
CivicSi95
Honda Civic (2006 - 2015)
Nov 22, 2008 11:20 AM
ekhatchgirl
Aug 2, 2005 12:21 PM
abolish415
Jun 4, 2005 11:01 AM
gsrhatch530
Mar 28, 2002 05:10 PM
