Clutch squeaks-annoying
is it the clutch (coming from the engine bay) or is it sqeaking near the clutch cylinder just above your pedal inside the cabin? You may need some moly-grease for the pedal assembly in the cabin area.
i had the same problem, and found out that it was the throwout bearing. My clutch was in need of replacement so i got a new clutch kit and included was the throwout bearing. Ever since i haven't heard the squeaking sound.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdelMsolG »</TD></TR><TR><TD CLASS="quote">it could possibly be the throwout bearing. sometimes they start with a faint squeak then turn into a nasty noise.</TD></TR></TABLE>
x3 on the throwout bearing. Too bad the transmission has to come off just to change one little part but it's a great opportunity to replace the clutch and possibly the rear main seal (just for good measure).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi »</TD></TR><TR><TD CLASS="quote">is it the clutch (coming from the engine bay) or is it sqeaking near the clutch cylinder just above your pedal inside the cabin? You may need some moly-grease for the pedal assembly in the cabin area.</TD></TR></TABLE>
Engine bay
I looked around on the web for about an hour and found some people fixed the squeak by removing the slave cylinder (if thats correct, the guide was a little confusing) and lubricating the ball joint with lithium grease so I guess I'll give that a try.
Engine bay
Nataku
Sep 18, 2010 06:22 PM
