wiper question on my cx?
Old Jun 10, 2008 | 04:51 AM
hondaon18's's Avatar
Default wiper question on my cx?
ok i going to try to explain what i want to do and see if any of you guys understand what i want to happen. ok i have a cx hatch and you guys know that the cx hatch only has to speeds on the wiper switch. what i want to know is if i use the wiper switch from a si hatch what else would i need to make it work cause the si hatch has three speeds. also i know that i would need a rear wiper but i don't want one so im not worried about the rear. all i want to know is what would i need to make the si switch work on my cx. i plugged it in already and only the two speeds work. thanks. i hope its not confusing what i wrote?
Old Jun 10, 2008 | 05:29 AM
davefromPA's Avatar
Default Re: wiper question on my cx? (hondaon18's)
oddly enough hondaon18's, i did the same thing. i put on the wiper lever from an lx which also has an intermittent level and not just low and high. it does not work on intermittent on my car like yours. i wonder why that is. any help would be great
Old Jun 10, 2008 | 12:00 PM
davefromPA's Avatar
ayone?
Old Jun 10, 2008 | 12:11 PM
Relic1's Avatar
All you need is the switch and an ICU that plugs into the rear of the fuse box.
I did this to my VX and several other EGs. Works perfectly.
Old Jun 11, 2008 | 04:56 AM
davefromPA's Avatar
Default Re: (Relic1)
what is this icu? will that be on the donor car?
Old Jun 11, 2008 | 06:14 AM
Relic1's Avatar
the ICU is the box that plugs into the back of the underdash fusebox, it will be in the donor car.
I don't have a pic of it, but it's really obvious when you see it.
Old Jun 11, 2008 | 07:04 AM
davefromPA's Avatar
thanks!! appreciate that
Old Jun 11, 2008 | 06:17 PM
Default Re: (davefromPA)
what switch im lost. is this so the wiper can work in the rear? cause that is not what i want i want to make the int to work!
Old Jun 11, 2008 | 08:47 PM
Relic1's Avatar
a car without int option does not have the wiper switch to select it.
You need the wiper switch with int location and the ICU from a car with int from the factory.
If you have the switch all ready, all you need is he ICU.
Old Jun 12, 2008 | 09:41 AM
okay do you have a picture of it to see what you is talking about. cause i still confused. where would this be at or how can i locate it.
Old Jun 12, 2008 | 10:59 AM
Relic1's Avatar
how to do the wiper install... DIY. (I just found this, guess I don't have to write one after all)
http://www.civicvx.com/diy_articles.html (at the bottom of the page)
Old Jun 12, 2008 | 07:28 PM
what all that to make my inter work . will any icu work off a four door civic with the inter option
Old Jun 13, 2008 | 04:07 AM
davefromPA's Avatar
Default Re: (hondaon18's)
yes. it should. thats how im doing mine. off of a four door lx.
Old Jun 13, 2008 | 06:21 AM
Fullthrottle297's Avatar
so cx's didnt come with intermittant wipers ? or was it just for certain years because my car has intermittant wipers and im pretty sure the old guy i bought it off of didnt install them
Old Jun 13, 2008 | 08:12 AM
Relic1's Avatar
int wipers was an option. (rare for the CX)
csp39
May 26, 2012 05:05 PM
GoodClothes
Jun 10, 2007 12:09 PM
mugenhatchie
Mar 16, 2007 10:42 PM
lv6l
Apr 20, 2006 04:17 PM
b18c5go
Mar 22, 2002 08:59 PM
