92 teg: 4 ways work, Turn signals don't
Old Jun 9, 2008 | 09:18 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default 92 teg: 4 ways work, Turn signals don't
like the title states, i remember wayyy back my signals used to work..
i installed a 96 spec ITR steering wheel, could that affect anything in my steering column? i don't appear to have any shorts, all fuses are good..
chime in guys
Old Jun 9, 2008 | 09:22 PM
db-1charlie's Avatar
Default Re: 92 teg: 4 ways work, Turn signals don't (ohsnapzafingcu)
You could of pinched some wires when you installed it. You could go over the fuses. also try to check the relay to the signal and see if there is power. if not you need to track down where the wire is fkd
Old Jun 10, 2008 | 07:40 AM
Default Re: 92 teg: 4 ways work, Turn signals don't (db-1charlie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db-1charlie &raquo;</TD></TR><TR><TD CLASS="quote">You could of pinched some wires when you installed it. You could go over the fuses. also try to check the relay to the signal and see if there is power. if not you need to track down where the wire is fkd</TD></TR></TABLE>
i'll check it tonight.. happen to have a diagram handy?
Old Jun 10, 2008 | 12:43 PM
lugnutRS's Avatar
This might sound crazy but check your fuse for the cigarette lighter.
Old Jun 10, 2008 | 04:32 PM
Default Re: 92 teg: 4 ways work, Turn signals don't (lugnutRS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lugnutRS &raquo;</TD></TR><TR><TD CLASS="quote">This might sound crazy but check your fuse for the cigarette lighter. </TD></TR></TABLE>
sucker works, lol i had to have it to plug the wideband in..
Old Jun 10, 2008 | 04:42 PM
4crx4me's Avatar
Check the ICU?
si90rex
11
Jan 31, 2008 06:40 PM
BlueIntegraBoy
Oct 20, 2006 05:38 PM
smokingemcee
Jun 9, 2006 10:20 PM
Stingray96
18
Dec 23, 2005 10:44 AM
_Spugen_
Oct 8, 2004 06:09 PM
