head gasket question
Old Jun 9, 2008 | 06:21 PM
japanstar_ef9's Avatar
Default head gasket question
i put a brand new head gasket on my b20 and torqued it down to correct specs, the motor was not turned on. the head was only torqued down for about 1 hour and i realized i needed to take the head back off. my question is do i need another new head gasket to finish or can i use the one i just had . i also am using copper spray gasket sealer.
Old Jun 10, 2008 | 05:46 AM
1992Si's Avatar
IMO yes. You have already compressed the gasket.
You may want to PM one of the tunrers in the Drag Racing forum.
Tony1 is always a big help.
or Jeff@Tempest.
Old Jun 10, 2008 | 10:32 AM
Golden Eagle's Avatar
Default Re: head gasket question (japanstar_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japanstar_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">i put a brand new head gasket on my b20 and torqued it down to correct specs, the motor was not turned on. the head was only torqued down for about 1 hour and i realized i needed to take the head back off. my question is do i need another new head gasket to finish or can i use the one i just had . i also am using copper spray gasket sealer.</TD></TR></TABLE>no you should be fine as long as you didn't run a heat cycle threw it.
autowrench07
Jul 26, 2012 07:55 AM
john457
Jun 5, 2007 05:25 PM
jdub db8
May 28, 2004 09:23 PM
petrv
Apr 12, 2004 08:18 AM
