Brake light/ Reverse light problem..
Old Jun 9, 2008 | 05:34 PM
driveitright's Avatar
Default Brake light/ Reverse light problem..
Was wondering if anyone could link me the code for the proper brake light bulb for a 95 civic hatch, and also where could I get the plugs for the reverse lights, for some reason mine doesn't have them? Appreciate any help in advance!
Old Jun 9, 2008 | 05:47 PM
1CaMw0nDeR's Avatar
Default Re: Brake light/ Reverse light problem.. (driveitright)
So you're saying that your hatch not only doesn't have reverse lights, but it doesn't have the plugs in which the bulbs mount into..??
Old Jun 9, 2008 | 06:20 PM
Correct, the bulbs/plugs aren't there, there was a white paper cover over the hole for them. And I am also missing one brake bulb but am not sure where to get a replacement.
Old Jun 10, 2008 | 03:39 AM
Nobody has any idea where I can find this stuff..?
Old Jun 10, 2008 | 04:35 AM
h2392si's Avatar
Default Re: (driveitright)
Dealership. Or try to find them at a local junkyard/dismantler in your area. I had to buy mines because the person before me cutt them off as well. Dealership or http://www.hondaautomotiveparts.com/ probably a little cheaper. Good luck.
Old Jun 10, 2008 | 09:38 AM
Default Re: (h2392si)
I know "where" I can get it, but I'm not sure exactly what part I need.
Old Jun 10, 2008 | 10:51 AM
h2392si's Avatar
Just link to it and put your cars info in. Choose the desired group of parts and click on it. It even gives you the part numbes. You can always call the dealer and tell them what you need and most likely they will have it and rapr you on the $$$
Old Jun 10, 2008 | 11:15 AM
BlackoutVTi's Avatar
And your bulb type is 1156 for inner tail light, rear signal, and reverse light. 1157 is the bulb for your outer brake lights.
Any more info you need for the bulbs is at http://www.sylvania.com/Consum...s.htm
Old Jun 10, 2008 | 06:34 PM
Default Re: (BlackoutVTi)
http://www.hondaautomotivepart...9.gif
I think I need #15 because the plugs for the reverse light bulbs aren't there... is that right? :x
Old Jun 11, 2008 | 03:16 AM
...anyone? Trying to get this fixed...
Old Jun 11, 2008 | 03:49 AM
h2392si's Avatar
yes, that's the one.
swizz977
Nov 16, 2014 05:48 AM
professorman
Oct 27, 2013 06:28 AM
djevolution04
Honda Civic (2001 - 2005)
Nov 8, 2011 06:47 AM
EASY101
Jul 10, 2006 02:26 PM
boris2286
May 5, 2005 02:54 PM
