Brake light/ Reverse light problem..
Was wondering if anyone could link me the code for the proper brake light bulb for a 95 civic hatch, and also where could I get the plugs for the reverse lights, for some reason mine doesn't have them? Appreciate any help in advance!
Re: Brake light/ Reverse light problem.. (driveitright)
So you're saying that your hatch not only doesn't have reverse lights, but it doesn't have the plugs in which the bulbs mount into..??
Correct, the bulbs/plugs aren't there, there was a white paper cover over the hole for them. And I am also missing one brake bulb but am not sure where to get a replacement.
Re: (driveitright)
Dealership. Or try to find them at a local junkyard/dismantler in your area. I had to buy mines because the person before me cutt them off as well. Dealership or http://www.hondaautomotiveparts.com/ probably a little cheaper. Good luck.
Re: (driveitright)
Just link to it and put your cars info in. Choose the desired group of parts and click on it. It even gives you the part numbes. You can always call the dealer and tell them what you need and most likely they will have it and rapr you on the $$$
Re: (h2392si)
And your bulb type is 1156 for inner tail light, rear signal, and reverse light. 1157 is the bulb for your outer brake lights.
Any more info you need for the bulbs is at http://www.sylvania.com/Consum...s.htm
Re: (BlackoutVTi)
http://www.hondaautomotivepart...9.gif
I think I need #15 because the plugs for the reverse light bulbs aren't there... is that right? :x
